Minolta X-700 35mm SLR Camera Logo
Posted on Jan 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What type batteries for minoltax-9 - Minolta X-700 35mm SLR Camera
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Minolta Master 102,366 Answers
  • Posted on Jan 17, 2010
Minolta Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443379
Points
622693
It uses either two 1.55V silver-oxide (SR-44 or equivalent) batteries OR two 1.5V alkaline-manganese (LR-44 or equivalent) batteries OR one 3V lithium (CR-1/3N) battery.
tip
Looking for the longest battery life laptop ?
We’ve yet to see a Windows laptop with battery life longer than 5~7 hours, unless we add an extended battery to the system. But when hpand dell launched its new series of laptops last week, one big push wasfor longer battery life.
When you purchase your notebook, charge the battery to 100 percent,discharge it completely, and then fully charge it to 100 percent againto help the battery remember exactly how much electrical charge it canhold. From then on, you’ll never need to completely discharge the laptop battery again, but always make sure when charging it that you let it reach 100 percent. DeHoop told us to “remember to plug in the laptop AC adapter(or dock/port replicator) whenever you get a chance. Most notebookswill recharge quickly.” Salinas had another tip for your batteries:“Keep them cool. Exposure to high temperatures can be a battery’s worstenemy,” he said
Hope the list can give you some help when you purchase a laptop or battery:
Top 5 long battery life for laptop
HP/Compaq Business NoteBook 6715B Battery 6 cells 4400mAh Description:
Type: Li-ion, 6 cells
Voltage: 10.8V
Capacity: 4400mAh
UL certificated cells inside!
Original HP Pavilion dv8000 Battery 8 cells 4400mAh Description:
Voltage: 14.4V
Capacity: 4400mAh
Type: Li-ion, 8 cells
Color: Dark Grey
Dimension:205.40 x 69.80 x 20.90 mm
Status: New and original.
Packing: Plain Box
Dell Inspiron 6000 Battery 9 cells 6600MAH Description:
Type: Li-ion, 9 cells
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
HP/Compaq Pavilion DV6000 Battery 12-cells 8800MAH Description:
Cell Type: Li-ion, 12-cells
Voltage: 10.8V
Capacity: 8800MAH
Dell Inspiron 6400 Battery 9 cells 6600MAH Description:
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
on Feb 24, 2010 • Computers & Internet
Reset battery
Get a serial cable. It's DB 9 to a DB 24. Connect to the UPS by using hyperterminal. Connect at 1200 bps. 8N1 xon/xoff. Type "S" the status of the UPS will come up. Type help for more commands.
Battery specs for IBM T43
Voltage: 10.8 Volts
Capacity: 4400 mAh
Battery Type: Li-ion 6 Cells
Voltage: 10.8 Volts
Capacity: 6600 mAh
Battery Type: Li-ion 9 Cells
Battery dead 2003 S type. Cannot gain access to rear luggage compartment
plug a cheap jumper battery cable into the cigarette lighter. They are the kind that has a cigar lighter plug at each end. Or, hook a 9 volt battery to a cigar lighter plug. That should be enough to operate the trunk switch.
I need a new battery for my 1986 Oldsmobile ninety-eight regancy sedan. fully loaded. what type of battery would i need?
Attributes Battery BCI # : 75
Battery CA @ 32 Degrees F : 775
Battery CCA @ 0 Degrees F : 630
Battery Height : 7 1/4"
Battery Length : 9 3/4"
Battery Posts Type : Side Post
Battery Reserve Capacity : 90
Battery Voltage : 12 volt
Battery Weight : 33 lbs.
Battery Width : 7"
Wet or Dry : Wet
A lead acid battery with the fallowing specs
group 75
Battery Width : 7"
Wet or Dry : Wet
Battery Width : 7"
Wet or Dry : Wet
Battery BCI # : 75
Battery Width : 7"
Wet or Dry : Wet
Turntable will not rotate. Belt is good. Motor does not turn and is warm. Shaft of motor turns freely. Is the motor bad or could it be something else?
Determine if it is a mains powered motor or a 9 - 12 volt type (it should say on it). If it is a 9-12 volt type you can disconect the wires and apply a 9 volt battery to it. If it doesn't turn it with that it's gone!
Top Minolta Photography Experts
ZJ Limited
ZJ Limited
k24674
Are you a Minolta Photography Expert? Answer questions, earn points and help others
