Question about E-Machines T6520 PC Desktop
Restore cd was installed now it wont start. it states that WINDOWSsystem32configSYSTEM is missing or corrupt
Posted by burnsmf on
Anonymous
  • 558 Answers
You will need to do a fresh install as the file windows needs to start is corrupted.Run the restore cd once more and re-install the os.
Good Luck
Posted on Jan 17, 2010
2answers
I have a problem with my netbook which can't start, I have this message: ...the following file is missing or corrupt: windowssystem32configsystem
Hi
Windows system 32 config file is part of the operating system and when this is missing or corrupted, you cannot boot up your computer. The only solution is to reinstall or repair your operating system. Good Luck.
Computer beeps twice at power up and will not start up. I get an error message that the following file is missing or corrupt windowssystem32configsystem. I have installed the original set up CD-ROM and hit...
i think you have motherboard problem or problem with the RAM ... try to replace the RAM and then start the machine...
if the problem persists ...to install a new copy of windows
I have an hp 511w that displays the message file missing or corrupted. WINDOWSSYSTEM32CONFIGSYSTEM that is the last screen i can access. anything i try to do (like push f8 or f1) doesnt work. i cannot...
You most definately have to restore windows.That system 32 config file is part of the boot process.Yours got corrupted .I take it your computer is out of warranty.If its not try calling hp and maybe they might send you recovery cd.
Good luck
2helpful
2answers
Turn on emachine, and dos menu pops up saying windows could not start because the following flile is missing or corrupt: WINDOWSSYSTEM32CONFIGSYSTEM then under that it says, you can attempt to repair this...
Borrow an installation Cd of your OS. Configur your computer to boot from CD.
Boot from CD, Choose (R) repair option. The recovery Console appears. Enter the number (1, 2 or other) that corresponds to the partition the system detected. If you see only one installation then you enter 1. You will then be asked to log in as administrator by supplying the password you entered whwn you installed.
When the C:\> prompt appears type
COPY [your_file_name] [SPACE BAR] C:\WINDOWS\system32\ [your_file_name]
After that Press [CTRL][ALT][DEL] to restart.
It should copy the missing file and you will be able to reboot.
Hope it helps
Rate the solution if it solves your problem.
1helpful
2answers
WONT START - SAYS WINDOWS\SYSTEM32\CONFIG\SYSTEM
See if you can borrow an installation cd from a friend. DO NOT use an OEM disc or one supplied by dell...compaq etc because they use different passwords and stuff.
Then go into system repair console. Check on google to go from there.
Hank
Inspiron 6000 wont boot, |windowssystem32configsystem missing or corrupt
you need to insert your windows xp boot able cd and boot from it than repair your system
Aspire 5610 file is missing or corrupt
The error message means you use the Windows installation CD to repair Windows by booting up with the Windows CD and select r at the first screen to start repair.
Windows xp corrupted
This is supposed to be caused by some missing registry entries in your windows installation. Not exactly sure why this is happening. May be you have some important files that cannot be copied due to a damaged CD. Microsoft replaces the media for you so that you can try installing using the replacement. Click here for more details
http://support.microsoft.com/default.aspx?scid=kb;en-us;326246
You can also try to recover the PC using recovery console. To do it follow the steps below
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:windowssystem32configsystem c:windows mpsystem.bak
    copy c:windowssystem32configsoftware c:windows mpsoftware.bak
    copy c:windowssystem32configsam c:windows mpsam.bak
    copy c:windowssystem32configsecurity c:windows mpsecurity.bak
    copy c:windowssystem32configdefault c:windows mpdefault.bak
    delete c:windowssystem32configsystem
    delete c:windowssystem32configsoftware
    delete c:windowssystem32configsam
    delete c:windowssystem32configsecurity
    delete c:windowssystem32configdefault
    copy c:windows epairsystem c:windowssystem32configsystem
    copy c:windows epairsoftware c:windowssystem32configsoftware
    copy c:windows epairsam c:windowssystem32configsam
    copy c:windows epairsecurity c:windowssystem32configsecurity
    copy c:windows epairdefault c:windowssystem32configdefault
  6. Type exit to quit Recovery Console. Your computer will restart.
Source:http://support.microsoft.com/kb/307545
E-Machines T6520 PC Desktop Logo
Top E-Machines Computers & Internet Experts
Ekse
Michael Thomas
Michael Thomas
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
