Question about Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Ultima keeps displaying an F10 fault and doesnt spin correctly. However, if I then switch it to a rinse and spin cycle it seems to spin OK.
Posted by mpkadudes on
Barry Coates
  • Hotpoint Master
  • 3,463 Answers
F10 meanswater level pressure switch not sensing correctly, there could be a blockage in the switch hose or chamber, or the switch could be faulty.
Posted on Jan 17, 2010
Paul Frindle
    New Friend:
Check that your water pressure is not too high and filling the machine too quickly!
If the machine fills up and operates the pressure level switch too soon (in time) after starting to fill, it will display F10, pump out the water and stop.
Fix - simply shut down the inlet tap to reduce the rate it fills up..
It took ages to find this - after I had spent days checking everything else and also replaced the pressure switch.
Posted on Aug 25, 2012
F05 keeps coming up on my ultima 860 hotpoint 1600 spin w/m,we cant find manual,what is problem?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Fo5 is a pressure switch fault; areas to check are pressure chamber for blockage, pressure pipe sump and pump. Click on a link for more Hotpoint, Creda and Indesit error code definitions or Hotpoint WMA / WM workshop manuals
Mar 05, 2010 | Hotpoint Ultima WF860 Front Load Washer
F-10 fault code
F10 is indicating pressure switch not sensing correctly.
Check connections from pressure switch to module.
Please rate my solution.
Thanks.
Nov 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt960
F10 means that the water level switch is not sensing the correct water level, this can be caused by faulty switch, a blockage in the pressure system, a blocked drain pump or filter.
It is a process of elimination I'm afraid.
Please rate my suggestions to solve your problem.Thanks.
Mar 01, 2009 | Hotpoint Ultima WF860 Front Load Washer
F10 FAULT CODE
F10 means that the pressure switch (water level switch) is not sensing the correct water level.
This can be for one of several reasons.
Firstly ,clean filter, if no filter at front behind bottom panel ,then remove lower rear panel, remove large black hose from bottom of tub, remove and clean filter inside..
Detach pressure switch hose attached to plastic chamber which comes from large black hose, this is a small plastic hose, blow down it , and you should hear the switch click if you listen carefully.
If you cannot hear it click, then switch is probably faulty, follow hose to switch.
Make sure the plastic chamber is not blocked where the hose is attached at bottom end.
Plz rate my solution.
Thanks.
Jan 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
Wf860 Error Code: F10
hiya
this could be caused by a faulty pressure switch (controls water levels). but due to the machine sharing the same electrical components as indesit it could be a fault on the main pcb.
hope this helps
please dont forget to rate the helpfuness of this reply, thanks kj
Jul 29, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima W860
hi there f10 fault code means pressure switch not sensing,
this could be to do with low water pressure or a bad connection on the pressure switch or control module which is located at the back left hand corner of the machine, remove backplate to gain access and remake all connections on module, if this should not resolve the fault i would be looking to replace the pressure first part no= C00112659 cost about £15
ps. always disconnect from mains before carrying out any work
Oct 20, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
gbob59
Lawrence Oravetz
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
