Question about Ariston Technologies Ovens
We need a new Campini ty60 thermostat but can not find where to get one
Anonymous
    New Friend:
See eBay there is one listed.
Posted on Jan 17, 2010
How to replace the thermostat on BP y-600
Turn off gas supply. Open panel on left side. Loosen the top and bottom unions. Remove thermostat capillary line from the oven. Now remove thermostat with 2 pipe wrenches. install new thermostat and attach assembly to the unions you loosened. Now insert the capillary line back into the oven.
Jul 27, 2014 | Bakers Pride Y-600 Gas Single Oven
Need part for an older Gibson wall oven
IF YOU CAN NOT FIND ONE ONLINE HAVE SOMEONE INSTALL A GENERIC THERMOSTAT BUT BE SURE THEY ARE KNOWLEDGABLE TO DETERMINE PROPER VOLTS / WATTAGES
Apr 21, 2014 | Ovens
CAMPINI Ty60
It is a thermal limiter. Same happened to me with kenwood . Am in the process of sourcing repacement. Can only find on the overpriced sites at mo eg partsmaster
Apr 11, 2012 | Baumatic B205SS Stainless Steel Electric...
Bake element will not shut off at set temp.
You need to check the oven cycle relay,
  1. Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!
  2. In order to gain access to the oven cycling relay, refer to your owner's manual. Removing the back panel of the range accesses most relays, but some ranges locate the relay under the oven compartment where the utility drawer is usually located.
  3. Now you can test the relay using your VOM. First, label each wire attached to the relay and remove them from the relay terminals. Using your VOM's ohmmeter function, set the range to R x 1 and touch one test lead to the terminal marked L and the other test lead to terminal H2. There should be NO continuity. Next, test the terminals marked H1 and H2. Again, there should be NO continuity. Finally, test the S and R terminals. Continuity should exist between these two terminals. If your relay does not pass all these tests, it is defective and should be replaced.
  4. To remove the relay, undo the two screws securing it to the range and replace with the correct new relay. Refer to your wiring diagram and labeled wires to ensure that the wires are on the correct terminals. Now replace the back panel or drawer and test the oven.
Then you check the oven thermostat: When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced. Adjusting the thermostat: Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature.
If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration.
Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat.
To remove the thermostat: Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place. To install a new thermostat, reverse the disassembly procedures (Step 7 above), transferring the wires individually from the old unit to the new.
Hope this information helped you.
Jan 14, 2011 | Whirlpool RBS275PD Electric Single Oven
Main Oven Thermostat :- No control of Heat
Hi
If you cannot regulate the heat in your oven it is most likely that your oven thermostat has failed.
You will need to have a new one fitted. This link will show you whats involved and where to get the parts. ; www.wonderhowto.com/how-to-replace-cooker-thermostat-oven-250012/
Dec 16, 2010 | Ovens
Am looking for a Brisbane supplier for a Campini TY95 thermostat
don't know where you are ? but you can order on the web from www.apdepot.com. @ sears parts.com. and many others . that may be in your area . try google. for appliance parts.. mm
Jul 08, 2010 | Ovens
I have thermador Masterpiece M28RM-1 double oven that they don't make any more, and for which they don't offer spare parts. I need a thermostat. Can I get one anywhere?
I had the same problem (M28RM-4).
1) This type of thermostat can still be taken apart, ie. it is not riveted like the newer ones. Take it apart and clean the contacts. It should work like new.
2) Both upper and lower ovens work off the same type thermostat. If for some reason #1 does not work, swap the relay part of the thermostat. If it still does not work, it is in the bimetal thermostat part and that part will need to be swapped with the upper oven.
Email me if you have any questions: [email protected] .
Dec 14, 2009 | Thermador Ovens
New replacement thermostat needs calibrating on my Kenmore oven
There is no real way to calibrate the thermostat. Most ovens have the same problem. By lowering the setting slightly will help get a closer temperature. Sometimes similar thermostats are substituted and may not be exactly the same as the original that came with your oven. Hope my trying to answer your question was helpful, Thanks, Sea breeze
Mar 27, 2009 | Kenmore Ovens
Temp 50 degree too cold need to adjust thermostat on JGRS14
ive installed 100 new thermostats over the years and they are set from the factory.no adjusting.now some knobs have an adjustment on them.and some times customers got knobs mixed up and got the wrong one one there.
Jan 01, 2009 | GE JGRS14 Gas Single Oven
Ovens Logo
2,082 people viewed this question
Top Ariston Technologies Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
john h
Are you an Ariston Technologies Oven Expert? Answer questions, earn points and help others
