Question about Kenneth Cole Watches
Kennet Cole Mens Watch Model A126-08 KC1494 How to adjust time
How to adjust time and date?
Posted by genetsiu on
Anonymous
    New Friend:
I have a Kennet Cole Mens Watch Model A126-05 KC1296 and I'd liked to know
How to adjust time
Posted on Aug 26, 2010
Is it original or fake?
take to a jeweler and they can tell you right away, press the helpful button and check link below
Reason to Buy Kenneth Cole New York Mens KC9004 Automatic Contemporary...
Jan 10, 2016 | Kenneth Cole KC9004 Mens All Black...
How do i set time for Kenneth Cole Reaction New York Digital Chronograph Men's Watch # KC1494
How do i set time for Kenneth Cole Reaction New York Digital Chronograph Men's Watch # KC1170
Jan 09, 2015 | Kenneth Cole Watches
Kc9110
not able to know where is the button to adjust digital time n date
Jun 16, 2013 | Kenneth Cole Kc9110 Touch Mens Watch
I just bought a Kenneth Cole Unlisted mens watch. There is no instructions on how to set the day and date. Is it broken out of the box or are those dials just fakes? Jens
The Mode button on the bottom left hand side will set your "SET" buttons to work.
The first push of your Mode button will activate your Stop Watch. Press the top right button to time your subject. Press it again to stop timing your subject.
Pressing the bottom right button will reset your Stop Watch to zero.
Press the Mode button to release your Stop Watch function and return to the Telling Time function.
Press the Mode button twice and you'll be able to set your Alarm function. Your Hour number will be flashing. Press the top right button to set your Alarm Hour. If you Alarm Hour is for the afternoon or evening continue pushing until a "P" appears by your hour number . This will be your afternoon/evening hour. If there is no "P" that, of course, will be your morning hour.
Press the bottom right button to adjust the minute number of your Alarm function. Your minute number will be flashing. Again, using the top right button, you'll be able to adjust your minute number.
(If you hold any number changing button for a long time, the numbers will flash through rapidly.)
Press the mode button to release your Alarm setting function.
Press the Mode button three times to set the Time of Day on your watch. At this point you'll also need to push the bottom left button to activate your Time of Day function. after pressing the bottom right button your minute number will start flashing. Press the top right button again to adjust your minute number. Once that's done, press the mode button to release your time of day function.
Hope this helps!
Oct 18, 2010 | Kenneth Cole Watches
Kenneth Cole Reaction watch date set problem
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Oct 30, 2008 | Kenneth Cole RK5034 REACTION
Watches Logo
2,407 people viewed this question
Top Kenneth Cole Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
