Retro Popcorn Maker crank handle connection to kettle
I just took my new RKP-630 out of the box. I can't screw the crank handle into the kettle - the threads won't catch. Is this a common problem? How can I solve it? Thanks
worked like a charm!!! it didn't specify in the manual, but thanks to your suggestion i'm no longer frustrated!worked like a charm!!! it didn't specify in the manual, but thanks to your suggestion i'm no longer frustrated!
Here is a link to Nostalgia Electrics..Fill in their form and you can go from there. Here is the link... http://nostalgiaelectrics.com/default.asp?a=service copy and paste it into your browser or try to click on it..Hope this helps you..Wayne
Hello Dan, According to the manufacturer specifications, your popcorn popper has a 2 ounce capacity kettle. so you should be able to take those premeasured packets and by using exactly (close enough) half, get the desired results of pop corn out of your popper.
If you also want to use your own popcorn, here's some directions that will let you do that also.
First, turn on the popper and add 1 teaspoon of oil or butter, you can also use Land O' Lakes Margarine as it doesn't burn the popcorn like most butter will do so this is a personal preference (so you can use whatever your preference is but it must be melted). I've not tried it un-melted but I don't think it would work too well.
Then add ¼ cup of unpopped popcorn, brand doesn't matter. Wait and within 5 to 10 minutes it will hve popped.
Hope you find this Very Helpful and best regards!
You can visit http://www.nostalgiaelectrics.com/ and under the Customer Service area you will be able to print off a new manual. You can also call 920-347-9122 for assistance.
look at the bottom of the machine and find the name of the manufacturer. Find the company on google and you should be able to download a manual straight from their website
