Question about Tanita 1479V - Digital Pocket Scale / Jewelry Scales
When I turn on the pocket digital scale there are
When I turn on the pocket digital scale there are flashing numbers on the screen that won't stop flashing.there are on 4 buttonstopush,on,off,tare,mode.what am I doing wrong? John,[email protected]
  • Anonymous Mar 12, 2014
    Is there a wiring diagram for the us magnum 1000 xr digital pocket scales
  • Anonymous Mar 15, 2014
    I have a aws-201 digital scale when I turn it on it flashes random number and doesn't stop how do I fix this
Anonymous
    New Friend:
Threw it out the f____n window
Posted on Jan 17, 2010
  • stephan russell Jul 05, 2013
    think your right. nobody else has given a better solution
meandthee
Are the flashing numbers 50.00 in the gram weight? if so, it's asking to be calibrated-u need 50 gram weight-5 nickels with some scotch tape to make it heavier works well-
Posted on May 23, 2012
    it is not showing anything apart from HHHHH.
My insten pocket digital scale turns on to 88888 and then starts running random numbers and even after I hit tare it doesn't stop
If a different battery does not restore normal operation then it is time to accept the fact that the unit has died nobly and needs to be replaced.
Apr 10, 2017 | Pocket Health & Beauty
My digital gram scale does not work. the screen has some kind of word. Please help
Try recalibrating it by turning it on while holding the "tare" or "mode" button. It should show a raw data from the sensor then. Press the tare button again and it should calibrate the empty weight. Then it will show a specific weight you should put on, usually 100g. It should automatically finish calibration now. Hope this helps. The words before calibration on my scale was OUt2
Sep 24, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Numbers flashing on my digital scales
Check to see if you need new batteries, or just remove batteries and reinstall to reset device.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
May 23, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Pocket scales read hhh turn
Try this - While it is off, press and hold both the mode and the tare* keys at the same time and press the On/Off key - Release the keys and observe the display - cycle through a series of numbers. Press the mode key once and observe the display "CAL 0" "100.00" then similar numbers as before. This step calibrates
Check here - http://wiki.answers.com/Q/How_do_you_calibrate_digi_weigh_scale_DW-100AX_or_fix_errors_such_as_F--H_or_ERR?#slide=1
Apr 12, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Operating instructions for Volt -100 pocket scale
If you don't have the measured weights that sometimes come with scales or can be purchased individually, I'd recommend using a United States nickel/5 cent coin. They are supposedly an exact 5 g's each, and a Volt-100 scale requires 100 g's for recalibration. Therefore, you can recalibrate your scale using 20 nickels. I also use a Volt-100 and so far this has worked for me exactly; the most it's ever been off is .02 g, which is basically nothing.
What you do is remove your batteries, (I'd replace them with brand new ones if you have the option) then place the scale on a completely smooth, perfectly level, flat surface. Power the scale on, make sure it is reading 0.00, hold the M (mode) button until CAL comes on the screen, release the button for a quick second, then press it again one more time (quickly, don't hold this time), and then wait until "100.00 g" is flashing on the screen. Then you're going to place your 20 nickels on the scale as smoothly and with as little jostling or movement as possible. After a moment, the screen should read out "PASS". You then power the scale off (don't weigh anything before turning it off as it can possibly adjust the calibration you just set or weigh out heavily or light) and to test out your newly calibrated scale, turn it back on and weigh one nickel. It should be exactly 5 g's, with no more than a .02 digression in either direction if done properly. Good luck!
Jul 07, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
DigiWeigh pocket scale showing..UnSE code..what is UnSE code?
Remove the battery - this happens when the scale tries to use a dead battery instead of the wall power supply.
May 02, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
My scales i turn it on and the number keep going different and there is nothin on it
  1. First, try recalibrating the scale with nothing on it.
  2. If there is a reset button on the device, press it.
  3. Try replacing the battery.
  4. If it still acts up, it's probably time to get a new scale.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 18, 2011 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
When i turn on my digiweigh dw 100ax scales F--H appears on the screen how do i fix that and calibrate the scales when done
I thought the scale was just completely broken, I was able to fix by doing the following.
1. turn unit off
2. hold down the on/off/tare AND the MODE button.
3. The unit will come up with a bunch of numbers on the screen. Release the buttons
4. Press MODE once, you will see "100" flash on the screen. if you don't press the button a second time.
5. place 100g of tare weights on the scale.
6. Press MODE button again. After this my scale said PASSED and shut off.
7. remove tare weights and turn device on. It should now register properly.
In my case. the scale was misregistering the 50g weights as 75. I shut it off. I pulled up ever so slightly on the scale plate on the hinge side of the plate are repeated steps 1-7.
I have no idea why they don't have a 3 part calibration on these.
It is working like a charm now!
Sep 04, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Scale displays OUT2
you need just to recalibrate it:
The procedure is standard for semi-all models of pocket scales, but the way how to get to calibration mode differs from model to model (or vendor to vendor).
In brief:
1.While turn-on get to the calibration mode (by pressing and holding the ON button, or holding TARE while turinig on) You should hold this "magic" combination until the LCD will show a number (large number - it was more than 2000 in my case). This number is a raw data from the sensor.
2.Now release the "magic" button.
3.Press it one more time, the display will show 2Ero and then 100.0
4.Now put calibrated weight of 100 grams on the scale and wait 3 seconds.
5.Press "magic" button again.The display will show CAL and then PASS.
6.Now remove the weight and turn off the scale.
7.Thats all - now you can use your scale as usually.
Jul 26, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
F--H APPEARS WHEN TURNED ON AND FREEZES
that dosent work in the case of an f--h display at least in my case i think the f--h stands for f**king hopeless
Jun 17, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Tanita 1479V - Digital Pocket Scale / Jewelry Scales Logo
15,031 people viewed this question
Top Tanita Health & Beauty Experts
john h
Tom Chichester
ray gallant
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
