Pulp backs up and loads on screen with even just two carrots or one apple. Everything fits properly and the motor seems to be running just fine.
It sounds, depending on the age of the juicer, that the grinding wheels are either out of adjustment or worn. Thank you, Dana
Hello. This machine works on a back pressure system. You will find that the machine will work fine when you do a greater number of carrots or a larger number of apples. The two carrots or one apple are just "priming" your champion which is designed for a large capacity. Regards, Joe
And here is the instruction booklet just in case you do not have one:
http://drbenkim.com/pdf/champion.pdf
PS kindly rate my answer. thank you.
I understand that, Joe. Why does the pulp load on the screen, and how is that removed by back pressure? There is no expulsion of pulp even after several carrots, apples, bunches of parsley, or kale. No expulsion.
My Champion Juicer is not expelling pulp. The pulp loads on the screen. Do I need a new cutter?
I had same problem until I discovered the juicer doesn’t juice leafy greens without the greens attachment. Mine juices perfectly now.
