SanDisk Sansa Clip MP3 Player Logo
Anonymous Posted on Jan 16, 2010
It Keeps Freezing up and i want to know how to fix it
Anonymous
Level 3:
  • Master 593 Answers
  • Posted on Jan 16, 2010
Anonymous
Master
Level 3:
Answers
593
Questions
0
Helped
175426
Points
1850
Try this - Reset the device 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Or you can try to force MSC modes 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC. If none of this helps you might need to reload and update to the latest firmware or try and force recovery mode. 1. On your Sansa player, press and hold the Power/Menu button for 15 seconds to turn the device completely off. 2. Slide the Hold switch so the orange portion shows. 3. On your PC, double-click My Computer 4. On your Sansa player, press and hold the REC button while connecting it to the PC. 5. Release the REC button when a 16MB-FORMAT drive partition appears under My Computer. This may not work on your player not sure of the Model cut off.
My beko fridge freezers fridge keeps freezing
Your t'stat is probably bad. Should be easy to fix. At least it is freezing and not ruining your food from being too warm.
My screen keeps on freezing when i go to the internet to where i have to trun it off in trun it on whats wrong?
PS3 screen keeps freezing means hardware errors and need some maintenance. Do you know, send back to game shop is too expensive and waste your time. Learn the correct repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn :
DIY PS3 Repair Guide
Not only such screen freezing problem, you can repair other red and yellow light related issues as well.After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
1helpful
4answers
My hp netbook keeps freezing for no apparent reason. I think it's over heating, but I don't know how to turn the fan on a higher setting. What do I do?
when you turn on pc> press f2 on your keyboard> you'll go to the bios or blue scree> look for advance and you'll see where you can configure the setting for your fan.
Keeps freezing up
I just got Fallout 3 as well and as i start the game it will freeze up on me usually within the first minute or so. Sometimes it gets to the point when I take control I want to know if there is any way I can fix this please let me know...
Fridge keeps freezing
If u change the thermostat and it keeps freezing the heater or timer are bad
2answers
Chances are, they replaced the wrong parts, or didn't replace all the parts, assuming they replaced an electric motor kit. I would need to know the P/N of the electric motor kit to confirm what was replaced.
Based on the fact that it froze the drinking water tank, and if they replaced the electric motor kit, the problem is more likely the temperature sensor or the control board.
Let me know what the P/N is of what they replaced and we can be more precise.
1helpful
2answers
Wii Keeps freezing
You may check out Wii Fix Guide to fix the problem yourself. This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
GE EasyCam Keeps Freezing
plz sent me the driver [email protected]
i m very thankful to u
8helpful
5answers
My toshiba laptop keeps freezing unexpectadly
Whats causing my Toshiba Satellite U205-S5002 laptop to keep freezing? Need assistance on how to troubleshoot the problem.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
