Examine the printer and youwill see a depression that is designed justfor on finger.
Tug on it an the door will open and the cartridges will be exposed.
just press on th efront of each one at a time and each will fall forward.
position th enew one in a similar fasion and push itin place.
Then close the door and press enter.
you should be good to go.
Leading
cause of paper jams is debris/foreign objects that accidentally fell into the
paper feed area. Please follow steps below to fix the problem:
1. Remove
the sheets of paper from the feeder.
2. Grab a
flashlight and look inside the feeder for any debris or foreign objects.
3. If
you're willing and physically able, you may also turn the printer over. Any
debris should just freely roll out from the feeder.
4. If
feeder is clear, place the printer back on the table, open the printer cover
and remove the cartridges.
5. Check
the cartridge area for any obstructions/debris in the cartridge carrier's path
or the paper path.
6. If
cartridge area is clear, close the cover.
7. Unplug
and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
thanks you helped
