Question about Measuring Tools & Sensors
What is the ratio of gas to oil?
What is the ratio of gas to oil on a ryobi gas blower? One gallon to 3.2 oz?
Anonymous
    New Friend:
  • 79 Answers
You can run it with a 50:1 ratio. 1 gal gas to 2.56 oz. two stroke oil.
Posted on Jan 17, 2010
Testimonial: "Perfect. Just what I was looking for."
What is oil to gas ratio for a Ryobi TP30 pull start trimmer?
The Ryobi TP30 also has the model number RY52014. This 2-cycle engine uses a 50:1 gas to oil ratio. That means that for every gallon of gasoline, you need 2.6 oz. of 2-cycle engine oil. This information is available on page 9 of the manual. Manuals Lib has the manual for the TP30 trimmer here: https://www.manualslib.com/manual/143217/Ryobi-Ry52014.html .
I hope this helps.
Jan 29, 2017 | Ryobi Garden
Oil petrol mixture for Rockwell 26cc weedeater
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular.
Ratio GAS:OIL UNITED STATES OIL per 1 U.S. GALLON Gasoline
(128 oz.)
*INTERNATIONAL OIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)
*INTERNATIONAL OIL per 1 LITER Gasoline
(metric)
32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
Jan 01, 2015 | Weedeater Garden
What is the oil mix for 2 gallons of gas for a 2 cycle gas leaf blower
Only use 50 to 1 as that is what is specified.
To get 50 to one ratio with the 6.4 oz bottle of 2 stroke oil just add 2 1/2 U.S.. gallons and that will be 50 to 1 ratio so you will have the correct ratio .
Aug 11, 2014 | Husqvarna 130bt 130 Bt Gas Powered...
Two stroke ratio calculator
If you are referring to the fuel mixture, it is 50:1. So for one gallon of gas, use 2.56 oz. ( US measure) of two stroke oil. Gas Oil Mixture Ratio Calculator
Jun 30, 2014 | Garden
Ounces per gallon 31 cc engine
If this is a 2-cycle engine, Ryboi are 50:1 check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 50:1 ratio (1 gal.) Gas to 2.5 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
Oct 07, 2013 | Ryobi Backpack Blower 25.4cc
Oil ratio
I use one of those small 2.6 oz oil containers in a gallon (128 oz) to give a 50:1 mix. If you want more oil in your mix add another container - but it will be more expensive and waste oil.
Apr 23, 2013 | Hitachi RB24EAP 23.9cc 2 Stroke 170 MPH...
What is percentage of oil for Ryobi cs 30
Fuel/Oil Mix ratio is 40:1. That is 3.2 oz oil per gallon of gas, or 1.6 ounces of oil/ half gallon of gas. I highly recommend using a good synthetic 2 stroke oil. Many benefits there.
Jun 08, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
What is the ratio of gas and oil mix for a ryobi 31cc trimmer
just use about 3 to 4 ounces of 2 cycle oil per gallon and you should be fine. a little extra lubrication wont hurt it
May 18, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Measuring Tools & Sensors Logo
143 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
