Every time i send a message it still sends but they do not show up in the sent box. i only get messages and never can tell what i said after i sent it. It is a major inconvenience and could someone with some expertise advise me how to fix it
On the left hand side of your gmail window there is a sent mail link. If you click on that it will show all the mail you have ever sent. From here you can find the email you sent, open it up and copy the message from it to send to someone else. *** for getting the email message back, unfortunately that is impossible, once a message is sent there is no getting it back. Sorry.
Good Luck and vote for me if this answer helped you out.
Cheers.
for sending text messages : 1.go to your message settings and check the message center number to see if it is correct 2. call to your network operator customer care 3. request the message center number... 4.note it down 5. go to message settings>message center number 6. insert the number which is noted by you and save it
this solves your messaging problem ... Good luck
1. call to your network operator customer care 2. request the message center number... 3.note it down 4. go to message settings>message center number 5. insert the number which is noted by you and save it
In some mobiles like nokia we have sent and outbox as different. A message is saved in outbox only when the message is getting processed and it is not sent. It will be saved in sent msg when it is being sent.Which model no.u have?Please check do u have any sent box or not. If yes then check the messages which are sent by u in sent box. If no, then go to settings in messages and select message settings and select the message to be saved when sent.
Check in your sent folder and look at the envelope next to the message. Each envelope has a check box at the top right corner.
<>If the person you are sending the message to also has Verizon: -If it was received by the other person, the box will be checked. -If it has an arrow next to it, it's still in the process of being sent; possibly because the intended recipient is out of service. -If you click on the sent message and scroll down to the bottom, it will tell you what time the other person received it at.
<>If the person doesn't have Verizon, all the messages you send (regardless of whether or not they were delivered) will have an arrow in the box and it will not tell you what time the person received the message at.
Sometimes, a message will have an I in the box. I think it stands for Incomplete; this only happens to me when I send a message to more than one person and the message doesn't get delivered for some reason.
