Question about Makita 10" Miter Saw LS1030N
How do I install the spring after changing the blade on the Makita 10 miter saw
Posted by 2concerned2 on
  • Anonymous Mar 27, 2014
    Change saw blade
Anonymous
  • 2,176 Answers
What spring? do you mean the one in the guard? if so you don;t have to remove it to change the blade, give me the exact model number or you can go to makitatools.com and download a breakdown that shows the reassembly of the guard, it is not that hard, and also you can download an owners manual that shows the proper blade replacement procedure.
Posted on Jan 19, 2010
How to fit compression spring on makita LS 1040 mitre saw
Go to: http://www.ereplacementparts.com/makita-ls1040-miter-saw-parts-c-97_98_99_323.html. They also have a video on how the replace the blade. Look closely at the parts diagram to see how and where the spring fits and fit accordingly.
Sep 09, 2014 • Saws
11helpful
How do I assemble the blade guard for my Makita Miter Saw Model LS1030? I accidentally disassembled the guard it when changing to a new saw blade. I cant figure out how to get the tension spring back in...
lay the spring into the plastic safety cover, you will see a catch for one portion of the spring, the cover plate goes over it and there is a tab on it to catch the loose end and then the center plate which screws on to hold everything in place, check by turning the plate that holds it onto the saw for free movement. You can go to makitausa.com and in the header area on the right type in your model number ls1030n and you can download or look at a breakdown to see what I am talking about. Let me know if you need more assistance, just found your question.
2helpful
How do you change the blade on a GMC 10 inch cmpund miter saw?
With the saw unplugged, push the spindle lock in on the motor side of the saw (a short black rod) while turning the blade by hand. The spindle lock will seat and hold the blade still so that you can use a wrench to loosen the nut that holds the blade on. Use the spindle lock again for tightening a new blade on the saw.
Changing the blade
there is a nut holding the blade in the center , it is left handle thread , there should be a locking mechanism to hold the blade while you unscrew the nut
1helpful
How to lift blade on mikita 10 mitch saw
right side of saw is a spring loaded knob. push saw down and pull out knob - rotate knob 90 degrees.
3helpful
Makita 10 inch slide miter saw problem
Is this it? If not, go to Makita site & download image of your saw. Hope this helps:http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_LS1214FL.pdf
1helpful
Blade guard spring assembly for LS1011
here ya go Bob hope it helps
http://www.ereplacementparts.com/makita-ls1030n-miter-saw-parts-c-97_98_99_321.html
Makita ls1013fl I need instructions on how to install
I installed it by looking at the parts pictures in the manual and experimenting. Thanks for the try at helping me.
Joe
Makita 10" Miter Saw LS1030N Logo
Top Makita Saws Experts
ray gallant
Parson's Repair...
Parson's Repair...
Are you a Makita Saw Expert? Answer questions, earn points and help others
