Question about Black & Decker PI400AB Power Inverter
Black & Decker P1400AB fuse change
There is a fuse to replace inside the body of the Black & Decker P1400AB adapter that plugs into the 12v outlet of my car, but I can't open the body. There is a screw that I removed, but the body still won't come apart.
Posted by jrjacob_826 on
Anonymous
    New Friend:
If it is the fuse inside the cigarette lighter plug, just unscrew it and put a new fuse in.
If you mean replacing the two 25amp fuses inside the inverter housing, you can bypass the fuses by soldering the two sides together. Or, if you want to put new fuses in, heat the solder holding the fuses in until they pop out and insert new ones.
As for opening the housing, good luck!! I ended up using steel cutters to rip off the plastic. The best option would be to buy a new one and return the old one in the package.
Posted on Mar 21, 2010
Anonymous
    New Friend:
In the tip that goes into the cigarette lighter there's a diamond plated section just below the spring loaded tip. It may take some effort (pliers) but it unscrews and the fuse is between the spring and the tip.
Posted on Jan 24, 2010
jmsniper20
    New Friend:
Lift the two side of the sticker of the power button and indicator lights to unscrew the two tiny screws to remove the top black plastic bracket of the inverter. next unscrew all the side 4 corners and remove the soldered wire from the outlet then u can easily slide out the pcb parts of the inverter. hope that would help you.
Posted on Apr 11, 2011
I want to order a charger for my Black and Decker Bright Bar Model WLB26B 12v DC 500mA
Hello, Ford -
According to the website eReplacementParts.com, the charger for the Black and Decker Bright Bar WLB26B (DeWalt and Black and Decker part #5140044-94) AC Charger) is no longer available. It has been discontinued.
https://www.ereplacementparts.com/black-and-decker-wlb26p-led-bright-bar-parts-c-4167_4402_202474.html
You may be lucky enough to find one for sale on eBay.
Best wishes.
Mar 01, 2018 | Decker Drills
Black & Decker Cordless Drill will not charge battery
Either the charging adapter is faulty or the battery is worn out.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jun 03, 2012 | Black & Decker Black and Decker 18V...
What is the polarity of a 12v Black & Decker Drill?
centre pin on plug socket is usually positive...
think I would **** it and see ....if the replacement charger has a charge light it will probably not light if you have reversed polarity. Had the same problem with VHF portables ...I just cut the wire on new charger and tried both options ..reconnected and a bit of tape...voila.
There is little danger to your drill from getting it wrong as long as a the timing is relatively short.
May 29, 2012 | Black & Decker Drills
My unit will not charge at all. I get no lights! I have checked all the outlets I have used. It did work for awhile then it just quit taking a charge.
Did you try this?
Fuse Replacement (DC Accessory Adapter)
1. Remove plug from accessory outlet. Remove the gold cap by turning counterclockwise
and lifting off.
2. Remove center pin and spring. Remove fuse.
3. Replace fuse with same type and size fuse (8 amp).
4. Replace center pin and spring inside plug.
5. Replace gold cap by turning clockwise.
For assistance with your product, visit our website www.blackanddecker.com for the
location of the service center nearest you or call the BLACK & DECKER help line
at 1-800-544-6986.
Jun 13, 2011 | Black & Decker 400 Watt Electromate With...
I Have a Vector VEC011 Jump Start System and the battery has gone bad. Where can I find a replacement battery (12V, 9A) with Bolt on bus Terminals
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service.
Or, you may find a replacement battery here: http://www.batterywholesale.com/battery-store/SLA-batteries/
Sep 25, 2010 | Vector Manufacturing Simple Start Battery...
Vec010bd AC charger part # 5140045-34 question . . .
barrel pin 12v 500Ma is correct. the only other required stat that you need to know is that the polarity is( ---------that's how the inside pin polarity is shown on the transformer. Go to any radio Shack, and they have this charger in stock. tell them you need a 120v. a/c input, 12v. DC 500 ma output, with the center (inside) pin positive( ).It should be less than $20.00
Feb 20, 2010 | JUMP START SYSTEM
Fan blew 12v car fuse
You probably burnrd out the wiring into the lighter or, you burned the contacts in the lighter socket. You can not use an AC fan in a car. A car is DC.
Jul 09, 2009 | Radio Shack 120VAC 4" Fan
Fuse Keeps Blowing In Car Plug
try using a 3a or high fuse
You can buy a new car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand DUAL 7" dvd player
Feb 09, 2008 | Durabrand Portable DVD
Black & Decker PI400AB Power Inverter Logo
1,439 people viewed this question
Top Black & Decker Electronics - Others Experts
Sheldon Dedek
Vernon Taylor
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
