Question about Zebra 105Se Thermal Printer
Zebra 105SL print only half of label
I use Windows XP with Zebra 105SL 300dpi to print label with Ztool program, however only half-width of the label is printed, the other half on right hand side is blank. I tried with 105Se drive then it can print the whole lable, however when restart either computer or printer the problem is still happened.
Can you please advise what is the problem and how to fix it.
Looking forward for your reply
Thank you & best regards,
Bach.
Posted by qbphuong on
Anonymous
    Scholar:
  • 31 Answers
This can happen if your page size in your driver is not set to the actual label size. It can happen if you have old .dll driver files mixed with your mew driver installation.
This is what I would do:
Uninstall the driver completely - delete the icon in Printers and Faxes. Drop down the file menu there and choose server properties and remove the driver for all Zebra printers from the Drivers tab. Go into the LCD menu of the printer and load defaults. Go back into the LCD meny and look at the page width setting. Your printer has 300 dots per inch, so a 4 inch label would be 1200 dots wide.
Another thing to consider is that you may be trying to printer to a 300 dpi printer from a 203 dpi driver. Make sure that you choose 300dpi when you reinstall. This should work.... If not, repost with more details about your application and driver. I can assure you that this is not a printer problem unless half of your printhead has failed.... unlikely, but possible....
Posted on Jan 31, 2010
Zebra 105sl printer labels print too small
There are 3 different DPI Printheads for Zebra printers if you print a label set up for a 200 DPI Printhead on a printer with a 300 DPI Printhead installed it will be about 66% of the size.
Feb 13, 2014 | Zebra 105SL Thermal Label Printer
Zebra 105sl laebls always come out blank
Power on while holding the pause button for 5 seconds. This should print black bar across the width of the label. If this prints, then check the darkness parameter in your label format or driver. Also check to make sure your ribbon is feeding coated side out. There is a shiny side and a dull side to a ribbon. The dull side should be against the media. If it is leaving an image on the ribbon and nothing on the label the ribbon is either loaded incorrectly or not a zebra ribbon.
Oct 03, 2010 | Zebra 105SL Thermal Label Printer
I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this issue?
I am trying to print a label on the zebra 105SL but the font ...
www.fixya.com/support/t5406223-am_trying_print_label_zebra_105sl
Jul 11, 2010 - I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this ...
db:: 4.67::Crystal Report Label Won't Send To Zebra k9
www.hivmr.com/db/k99xad9dfspspddfs1scm9fzxxkdz9dj
My routine can print the label to any other laser printer, but the Zebra. ... I am tryingto find a way to print actual time a smartform label gets printed out on a zebra ... In this i want to changeCross Tab expert Row Label Font,Cross Tab expert ..... And labelpaper too. ..... DB:2.73:Zebra 105sl And Crystal Report Label Issues 1d.
db:: 5.16::Help My printer is printing in 3x5 documents and I ...
www.hivmr.com/db/xkzpajp81937ap7zdf87sdmsxmcm179m
DB:4.06:Printing 3x5 Continuous Feed Labels On Hp Officejet 6100 d8 ... Are they toosmall? ... I want to help you but I am not sure I can be of much help until I know what kind ... If the paper size is 3.5x5 but you are trying to print a 3x5 photo (which seems to be ...... I have a label format issue on a Zebra 105SL label printer.
db:: 4.15::Custom label sizes md - Hivmr
Jul 11, 2010 | Office Equipment & Supplies
Zebra 105SL Prints fine through Zebra Setup Utility, but prints plain text when file copied to port. Win XP. The setup utility can never get Version Info from the printer, but Windows shows the printer...
possible fonts issue. try to change the font from the text, check setings from the driver.
try to print from the driver (test print)
Try to print from Word (need to ajust the page) with diferents text fonts.
you can check the correct firmware ( be ware with the information about the serial number) ATENTION!!! wrong firmware can cause PRINTER DEAD!!!
Install lates firmware to the printer.
Oct 12, 2009 | Zebra 105SL Thermal Label Printer
Prints half the label.
Try reloading the forms from the AS400 by restarting the program. That should get it to work.
Jul 03, 2008 | Zebra 105SL Thermal Label Printer
Zebra 105sl - printer does not print correct size
This can happen if you have the wrong dpi setup. For instance the 105sl can be either 203dpi or 300dpi. If your printhead is 300dpi and the label you create is expecting 203dpi, then you will see shrunken label. Your situation doesn't exactly sound like this is the case but it may be worth checking.
Mar 21, 2008 | Zebra 105SL Thermal Label Printer
Zebra 105 SE Printing Blank Labels
You need the correct driver for the 105Se. The 300 dpi SL driver is not compatible.
Unfortunately, Zebra does not make it's older drivers available online. You will need to locacte someone with the correct driver for whichever version of Windows you are using.
Steve
Feb 13, 2008 | Zebra 105Se Thermal Printer
Zebra 105Se Thermal Printer Logo
2,029 people viewed this question
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
