When I change batteries I loose the date/time and other settings, even if the batteries were not dead and I do it within a few seconds. Is there another battery built into the camera? (the instructions say I should have several hours to make the change, without losing the stttings)
Peter.
There isn't another battery built into it. From what I undersatnd once you have placed batteries into the camera or connected the AC adaptor into the camera for 2 hours the camera will retain the date/time settings for 6 hours.
If they haven't been in the camera for two hours and you remove them the camera will loose the settings. If they have been in the camera for over two hours the camera will keep the settings for 6 hours. This leads me to think that a capacitor on the board inside the camera charges up for two hours and then slowly discharges over 6. Hope this helps.
Thanks Adam.
The problem is that it does not give me the 6 hours, or even two minutes!
I guess the capacitor in not holding any charge any more.
It would probably cost more to get it fixed than it is worth, but it has been a very good camera and still works well, apart from having to go through the set up procedure every time I change batteries.
