Question about Emerson EWR20V4 DVD Recorder/VCR
I can't get the DVD out of the player - Emerson EWR20V4 DVD Recorder/VCR
Posted by aharman43 on
Anonymous
    Scholar:
  • 108 Answers
Need a firmware upgrade. Emerson will charge you for it. Otherwise you need to find Dvds it will accept. Hard to do with all of the newer dvds. -RW only 1Xor 2X. -R 1X-2X. Memorex would not work for me. Multi- speed dvds over listed speeds will not work. Maxell -R 1X-4X worked for me. Good luck finding any.
Posted on Jan 16, 2010
  • Anonymous Jan 16, 2010
DVD region hack available?
If you suffer from region code troubles, you can download a region free DVD player software tool on your pc and then you can play discs of any regions you want. You can try Leawo Blu-ray Player which is a free Blu-ray player and a region free player.
May 03, 2016 | JVC HR-XVC1U DVD-VCR Combo
Is my mitsubishi dd 6030 a multi region player
Mitsubishi DD-6030 DVD Player Multi region hack ... - Fixya
www.fixya.com > ... > Mitsubishi > Mitsubishi DD-6030 DVD Player
Mitsubishi DD-6030 DVD Player, multi region hack related issues. Get free help ...Can you help? I need the multi region code for my Toshiba DVD SD370E. Ad.
Mitsubishi DD-6030 DVD Player Multi region hack code ...
Mitsubishi DD-6030 DVD Player, multi region hack code related issues. Get free help ... I need the multi region code for my Toshiba DVD SD370E. Ad. Question ...
Mitsubishi DD-6030 DVD Player Real free - Questions -Q&A
www.dqrkc.com/search/p153978-mitsubishi_dd_6030...player/real_free
I use them on all my disk players and they work real well. If you have any comments please feel free to leave them here. Hope this helps and thank you for using ...
Planet DVD Discussion Forum - planetdvd.net
www.planetdvd.net/discussion/wwwboard2.htm
Jan 20, 2016 | Mitsubishi DD-6030 DVD Player
DVD stuck in player. Now it does not respond to any buttons pushed.
Power up and press open button as soon as it starts to spin, some dvds lock with read errors, some spit the disc out..
If the belt is worn open unit, remove tray and replace rubber belt, if you dont have one use a thick rubber band.
if you cant access rubber belt, most dvd's have a slide underneath. use a small screwdriver and manually slide it open.
Read errors are not always the laser...so dont go and waste money.
If your dvd is not hq using dc brushless motors, remove loader, give the spindle and sled motor a good lube with wd40, spin the spindle moto up with 5-7 volts to clean the commutator.
Carbon builds up and the motors dont spin at correct speed.
Sled remove drive gear, usually pops out and burn it clean as above.
I have had good results with above since 2004, repaired 1000's of dvd's over my 14 years as senior engineer for wholesale importer in cape town.
Good luck
44ct357 CT SA
Jan 23, 2013 | Pioneer DV-C503 Multi-disc DVD Player
AFTER I HAVE RECORDED A PROGRAMME I AM UNABLE TO PLAY IT ON OTHER DVD PLAYERS ARE MY SETTINGS INCORRECT? THANKS
No,many small DVD players compannies makers used difference ending codes,that was patent by the big tv corporations,that also make DVD players.That why u couldn't play from one DVD player to the next DVD players.
Dec 06, 2010 | Wharfedale DVD-M3 DVD Player
Does cyberhome ch-dvd 300 dvd player play burned mp4 movies?
the answer is "No". Your player cannot play MP4 DVD discs.
Take care.
Jun 18, 2010 | Cyberhome CH-DVD 300 DVD Player
Recorded dvd's wont play on other dvd players
some dvd players (outdated)..will not play these new dvd (recorded or pre-recorded dvd)...if you are recording dvd and wish to play on another dvd player (dvd player must be at least 2009)...same thing happen with my toshiba recorder...my jvc player works its (2008), but my sony dvd (2004) did not play any of the recorded dvds (only the store brought).....suggestion buy a not expensive dvd player (you just need it to play all that other features will push the price range up)
hope this help
May 30, 2010 | Funai PY90VG DVD Player/VCR
Dvd player will not play dvds
Motor was not working. Disposed of old player and bought another dvd player
Nov 04, 2009 | Televison & Video
VHS to DVD-R dubbs fine: but won't play on SONY DVD player.
Please finalize burned DVD to play in another dvd player.
Apr 16, 2009 | Panasonic DMR-E75V DVD Player/VCR
Rotor doesn't stop after insert DVD
its seems that DVD player can't read the DVD. Can be: 1. DVD Player eye is dirty 2. DVD format on unknown to DVD player There are kits that clean DVD player eye, I would try it first.
May 19, 2007 | Toshiba SD4990 DVD Player
Emerson EWR20V4 DVD Recorder/VCR Logo
128 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
