Question about Microsoft Xbox 360 Controller
Wireless controller wont connect with xbox,just get flashing lights on controller
Posted by adamdouble on
Anonymous
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
Have you synced it? Try visiting my syncing tip to sync it properly.
http://www.fixya.com/support/r3915841-sync_xbox_360_wireless_controller
If that doesn't work you may have an internal controller error and your best bet is too replace it.
Posted on Jan 26, 2010
1helpful
My son has a xbox360 and were trying to get xbox live to connect and it wont we had it working just fine on his brothers hes not home so we hooked it up to the other xbox 360 and it wont connect
1 Disconnect all accessories and wired controllers from the Xbox 360.
2 Hold the "Guide" button down for three seconds on any wireless controllers, then respond to the prompt on your television screen to disconnect the controllers from your system.3 turn on the wireless headset by pressing the "Power" button in the center of the earpiece. 4 Press the "Connect" button on the front of your Xbox 360 system. 5 Press the "Connect" button on the wireless headset. The ring of lights around the power button of the Xbox 360 system should spin and blink once. One of the lights should remain lit up, indicating the port number that the headset is using. If you do not see any lights on the system, you may have a faulty wireless headset.6 Press the "Guide" button on your wireless controller to reconnect the controller to the Xbox 360 system. If you are using a wired controller, you can plug it back into the system.7 Press the "Connect" button on the top of your wireless controller to sync the controller with your system. You should see the connection light around the "Guide" button on the controller light up, indicating which port you are connected to. You should also see a corresponding port light in the ring around the power button of your Xbox 360 system 8 Press the "Connect" button on the wireless headset until the port light on the headset matches the light on the controller and Xbox 360 system. For example, if you are the first player, the light for port number one should be lit up on the Xbox system, the controller and the headset. When all lights correspond, your headset should be properly connected.
Wont stop flashing green and I can not connect to xbox live yet I used to be able to Any Help Thanks, Paul
IF The LIGHT IS FLASHING GREEN then there is something wrong with your wireless network
Check your network settings and Retry connecting
Check the adapter's status light loadTOCNode(2, 'moreinformation'); The adapter's status light can tell you a lot about the state that the adapter is in. Here's what the different lights mean:
  • Steady green light: The adapter is connected to a wireless router, gateway, or access point. The adapter is ready to use.
  • Steady red light: The adapter is not recognized. Try plugging the adapter into a USB port on the front of the Xbox 360 console.
  • Flashing green: The adapter is attempting to connect to a wireless network.
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support at http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) .
  • No light: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console
Wireless controllers wont work lights just keep flashing
Have you tried syncing the controllers to the XBOX?
On the front of the xbox there should be a small button next to the memory slots. push that and then push the small button at the back of the controller (near the port). After a few seconds, the controllers should connect.
Good Luck!
1helpful
Xbox 360 controller not working, all 4 lights are blinking.
The wired and wireless controllers can be actively connected to an Xbox 360 console all at one time. Each connected controller is assigned a quadrant on the Ring of Light. Before you can connect a wireless controller, at least one quadrant must be free and will be unlit.
Connecting an Xbox 360 Wireless Controller to an Xbox 360 Console is called Connecting. To connect a controller to a console:
First, Press and hold down the Guide Button on the wireless controller until it turns on.
Second, Press and release the power button to turn the console on.
Third, Press and release the connect button on the console.
Fourth, Press and release the connect button on the controller.
Fifth, After the ring of light on the controller and console spin and flash once, the controller is connected. The quadrant that remains lit indicates the controller's position.
Four Green lights on the controller's Ring of Light flash continuously
The Please Reconnect Controller message appears on the monitor
There is interference and the controller does not respond properly
Step 1: Ensure that either the AA batteries are new or the Xbox 360 Rechargeable Battery Pack has a full charge.
Step 2: Ensure that you have performed the proper procedure to connect the Xbox 360 Wireless Controller to the console.
Step 3: If still experiencing issues, ensure there is a clear line of sight between the front of the console and the wireless controller. If there are any obstructions, especially metal objects, remove them.
Step 4: 2.4 gigahertz cordless telephones, microwave ovens, and Bluetooth headsets for cell phones can interfere with the operation of the wireless controller. Turn off or unplug those devices and then try to connect the wireless controller to the console again.
Step 5: If these steps did not resolve the issue, the wireless controller may need to be replaced.
1helpful
My controller just shows all four lights flashing and when i try to sync it, the lights just keep spinning round and does'nt connect
Xbox controllerwirless wontconnect to pc
To connect the controller to a computer that is running Windows XP SP2 or a later version of Windows, follow these steps:
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that the Xbox 360 Wireless Gaming Receiver for Windows is plugged in to your computer.
  3. On the Xbox 360 Wireless Gaming Receiver for Windows, press and release the small round Connect button.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. The Ring of Light on the controller spins and flashes one time, and the light on the Xbox 360 Wireless Gaming Receiver for Windows flashes. When the controller is connected, the Ring of Light on the controller remains lit and indicates the position in which the controller is connected.
Note If you want help connecting an Xbox 360 Wireless Controller to your personal computer, you can contact Xbox Customer Support. For more information about how to contact Xbox Customer Support, please visit the Xbox Support (http://www.xbox.com/support/) Web site.
1helpful
Xbox-360 wireless controller doesn't sync at all
my xbox e87a2ee.jpg joystick this spot of cable is broke and i dont know what is sequece of colours in cable?
2answers
My xbox 360 and wireless controller will sync but then it wont show that they are connected and even though i turned on my console by using the button on the console it just shows the green light turn on...
To connect the controller to your Xbox 360 console, follow these steps:
  2. Make sure that your Xbox 360 console2_bing.gif is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console2_bing.gif.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  5. After the Ring2_bing.gif of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
2helpful
2answers
Wireless controller
press the little buton on the controller and the xbox and it should register
5helpful
Xbox 360 wireless control pad wont connect
have you tried to pair it... the little white button on both the controller and the 360? works just like the wii remote
Microsoft Xbox 360 Controller Logo
Top Microsoft Video Game Consoles & Games Experts
Ekse
Joseph Murphy
Joseph Murphy
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
