Check that ground is correctly connected. If nuetral is provided, ensure it too is connected. Your total load is 780 watts. Check power in and ground out of the supply side. There may be a fuse in the inverter on the output side also, replace if necessary. If fault light does not go out after these checks, you will need to contact Black and Decker who manufactures the vector series now.
