Try resetting the BIOS, depending on the motherboard, there will either be a button, switch or small jumpers that will short two pins and reset the cmos on the board. Just make sure to take out all the extra peripherals before powering back up. If you have jumpers, look for the one marked CMOS, not the one marked password. Move the jumper plug over one pin and power the system up. Wait approx. one minute and power back down, remove the power plug from the back and press the power button on the front to bleed off the power. Move the jumper back to its original place, plug the power cord back in and try booting the system back up. If it boots you will need to restart and get back into the BIOS and reset the time and date.
In Ubuntu 9.04 click on the main icon and select Restart.
- If Ubuntu is the only operating system on your computer you'll need to tap the ESC key as the system boots.
- If you have a dual boot or multiple-boot system the menu should appear on its own.
- At the root level you'll get a boot menu. Select the one that says "recovery mode" and press Enter.
- Ubuntu continues to load until you reach the Recovery Menu.
- Arrow down to "
netroot
" which states Drop to root shell prompt with networking and press Enter.
- Now, at the root type "
password username
" (where username is the account whose password you want to change) and press Enter.
- You'll be prompted to
enter a new password
- You will not see the password or any evidence that you are typing.
- Retype the password. If both passwords match you'll have successfully reset your password.
- Press Enter to continue booting into Ubuntu.
hope it helps
Reformatting as per new system.
From what you say I presume you wish to
put it back to when was supplied. If so, boot your computer and go
into the Bios, select default settings.
Re boot your computer with
your system disc in the DVD drive and when the menu asks whether you
want to install a fresh system and format, select fresh system.
When
your new system is installed, go to the manufacturers web site and
down load the drivers for your computer then re-boot it.
Install
Office and any other periferal software that was supplied with the
computer and there you have a system installed bare PC.
Hope that helps.
When
Install
Hope that helps.
put it back to when you bought it. If so, boot your computer and go
want to install a fres system and format, select that.
When your
new system is installed, go to the manufacturers web site and down
load the drivers for your computer then re boot it.
Install Office
and any other periferal software that was supplied with the computer
What did you put in? are you sure about the model? what is prompting you for power type?
