Question about Canon C2058 Color Copier
I got a pixma mx 330 yesterday. I installed the program with the cd, but it says the printer is not found.
Posted by tdecesar on
virtualhost
    President:
  • 2,185 Answers
Sometimes, you need to consider the OS you are currently using and the CD installer. They should be compatible because if not, you will be experiencing problems. What OS are you using?
Posted on Jan 16, 2010
How to recieve fax from canon pixma-mx 330
You will need to plug in a phone cable to the back of the printer. Then enter the printer's set up page by typing in the IP address of the printer into a browser and walk through the fax setup steps.
Mar 01, 2011 | Canon IP5200R Colour BubbleJet with...
Ink says low and its not out of ink . model mx 330 . installed new cartridge and this problem pops up when i print and this is a new cartridge.
remove the cartridge and clean it from the bottom reset your printer and then again try to print also check that you are updated in drivers
Mar 17, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
I just bought a Mx 330, but my coputer will not
The problem is very much likely to be your computer.
Enter your services menu in your computer and make sure that your hardware detection is enabled, the service name is "plug and play." Then from there click start to start that service and select that it's startup type is automatic.
Then scroll down to the print spooler service, make the startup type automatic and then start that.
Now turn off the printer, unplug the USB from it, plug it back in and turn on the printer.
Dec 14, 2009 | Canon PIXMA MX330 Multifunction InkJet...
Ca i recharge catridge form cnon pixma MX 330?, i
All catridges are made to show the ink levels only for 1st use, once you refill the cartridge you need to reset the ink level chip, some cartrides level cannot be reset, some can be re-set.
There are solution available for some specific printer ink cartridges on how to re-set the ink level.
You can google and loacte the solution giving cartridge number in the search field of google.
Dec 07, 2009 | Canon PIXMA MX310 All-In-One Printer
I lost my cd canon mx 310 installer what i have to do ?
You may check any of the links below and download the driver for free:
http://driverscollection.com/?H=PIXMA%20MX310&By=Canon
http://www.soft82.com/download/windows/canon-pixma-mx310-all-in-one-driver/
Have a great day!
Nov 01, 2009 | Canon PIXMA MX310 All-In-One Printer
"File ImageCach.ic could not be accessed"
The Canon Program "CD-Label Print" has issues with Windows 7.
I solved it this way:
  1. Find the "CDLabelPrint.exe" most likely under "C:\Program Files\CD-LabelPrint"
  2. Right-Click on the File and choose Properties
  3. Select "Compatibility" and tick "Run Program ... Windows XP (SP3)"
  4. Push "OK"
  5. You should be fine now
See Picture for Details.
May 11, 2009 | Canon PIXMA iP5200R InkJet Photo Printer
I am trying to figure out how to print a Half-Fold Greeting Card.
Check the cd that came with the printer, there should be a manual in it.
May 04, 2009 | Computers & Internet
I lost my cd and need to program my computer - how can I do that with out a cd??
Go here. It takes a few seconds to load all the files available. Select your operating system, and after a few more seconds, you should see the driver files to download. Follow the instructions to download and install the driver.
Apr 17, 2008 | Canon PIXMA MX300 All-in-One Printer
Canon C2058 Color Copier Logo
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
