Replace the motor position sensor also known as a 'hall' sensor. About $20. Pretty easy fix. Check out videos on , repairclinic.com , , appliancepartspros.com , or YouTube.com.
Pretty common erroron older units.
LG Washing Machine Displaying Fault Code IE or 1E
WM2016CW
WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
The FE error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced
Error Code PE mean Pressure sensor Error code Check
wiring connection to the pressure sensor; to solve it replace pressure sensor. The
sensor repair is simple and straight forward.
They have a small gauze type filter which fits in the pipe end going into the rear of the machine. Never had a problem with any other Hotpoint machine I had fitted other than LG which showed a similar fault . Try Using the original pipe not the LG Pipe as well to see .
