Question about Dell Dimension 2400 PC Desktop
At start up i get Alert! previous Fan Failure Strike the F1 key to continue F2 to run the set up utility. Do i need to replace the fan?
One of the cooling fans inside the case of the computer (where you put cd's in, and plug all your cords in. There will be at least 2 fans in your unit, but probably 3. The fans keep the computer running cool, preventing damage to the sensitve chips and electronics inside your computer. There is a big fan near the top of the case, this is for the power supply. This is probably NOT the culprit. You can remove one side of the case by removing two of three screws. (dont be nervous, you wont wreck anything.) With the case off, turn the computer on and look for the fan that is not spinning. Turn the computer off. Check the wires running from the fan to the computer (should be three) two are for power, the third sends the signal to the comp telling it its speed and whether it is working or not. If everything checks out, then you just need a new fan. There are only two sizes, but you should be able to remove the fan by disconnecting the wires (mark where they went!!) and removing the phillips (star) screws that mount it to your case. Take the old fan to radio shack or a comp. suppy store and match it up. All computer fans are 12v with 3 connectors. You should be able to manage this repair yourself. You will not break anything, just be sure the power is off when you are removing the fan and take care not to slip and damage something when you are removing and installikng the fan.
Cheers
Jer
Posted on Jan 16, 2010
Posted on Jan 15, 2010
Mar 27, 2012 | Dell Inspiron 620 ST Desktop Computer...
Aug 18, 2011 | Dell OptiPlex GX270 PC Desktop
Jul 20, 2011 | Dell OptiPlex GX520n PC Desktop
Feb 19, 2011 | Computers & Internet
Oct 14, 2010 | Dell XPS 600 PC Desktop
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Jul 30, 2010 | Dell Computers & Internet
May 28, 2009 | Computers & Internet
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
1,087 people viewed this question
