Question about Acer Aspire T135 PC Desktop
Acer Aspire X1301 is excessively loud, runs one speed always.
Acer Aspire X1301 fan is excessively loud and runs at one seed all the time.
Posted by skad on
Anonymous
    New Friend:
  • 10 Answers
Are all the vents clear from obstructions, fluff etc?
Posted on Jan 18, 2010
Acer Aspire X3300 not detecting on-board SATA controller
HINT:
1) Try to reflash the BIOS.
2) Look for new firmware Flash update /then reflash BIOS.
3) buy a new bios module equal to yours and seek help on tech to disoldering module to the new one.
Carl
Feb 24, 2016 | Acer New Aspire X1200 X1300 X1301 X1800...
I have an acer aspire x1301 and was wondering if you can connect any cooling fans
You can put cooling fans on anything. It looks like you can put a fan on the back, its looks to be a 80 or 92mm fan. I recommend a dual ball bearing fan if you go that route since they last longer. You can also put one on the side, if you cut a hole for one on the side. Another good option would be to upgrade the cooling for the processor with something that is all copper, and use artic silver 5 as the thermal paste.
Sep 11, 2013 | Acer Aspire T135 PC Desktop
Running an Acer Aspire ax5900. The video card fan vibrates loudly for the first 10 minutes of startup. I'm told I need a new video card. Area is clean and dust free. Where is the best place to find a...
Your Acer Aspire, like any other desktop computer system, contains fans inside the case to help vent the heat generated by the internal components.
These fans generally operate quietly and reliably, working in the background to prevent your computer from overheating.
A fan that sounds excessively loud could indicate a problem such as overheating or loose internal components, or it could simply be a normally loud fan.
The key to differentiating between the two involves looking for additional clues from your computer.
Normal Operation
Due to computer configuration and build quality, the fans in some desktops sound louder than others.
Depending on what other brands of computers you've owned or have had experience with, the fan in the Acer may sound louder, when it's actually functioning perfectly.
The fan will run to keep the inside of the computer from overheating, so periodic runs are normal. If the fan runs for long periods or very often, you may have a deeper problem.
Fan Damage and Overheating
A fan can sound loud due to damage, such as broken blades or to a build-up of dirt that impedes normal operation.
This dirt, as well as normal wear and usage, can wear away the lubricant coating on the fan's internal shaft, causing the blades to make excessive noise as they turn. In many cases, a loud fan indicates that the computer is overheating, causing the fan to run more often than usual to try and cool the system.
Depending on the types of components and upgrades within your Acer computer, your current fan may be too small and weak to handle the heat output, and require upgrading to a larger, more powerful fan.
Troubleshooting Take note of when the fan turns on and how long it runs to determine any distinct patterns, whether if it occurs only during certain processes or programs.
Your computer's CPU generates a large amount of heat while in operation, so programs that require large amounts of CPU usage may trigger the fan more often.
Watch for additional signs of overheating, such as sudden shutdowns or computer crashes. Check inside the case for signs of other components touching the fan and causing vibration noise.
Solution
Do not overtax the CPU by opening numerous processor-intensive programs at once.
Check that all screws, cards and wires are securely fastened and away from the fan.
Keep your computer clean inside and out, to prevent the build-up of dirt on the fan blades or air vents and minimize the threat of overheating.
Apply a drop of oil to your fan's shaft to give it proper lubrication and smooth, quiet rotation of the blades.
http://www.techrepublic.com/article/quiet-noisy-computer-fans-with-a-drop-of-oil/5034842
Aug 06, 2013 | Computers & Internet
No audio on acer aspire x1800
You can try updating your drivers. Go to your control panel and search for "device manager". Then find the audio devices section and click on each of them one at a time and select "search for driver updates". This should help with your problem.
Jun 22, 2017 | Acer New Aspire X1200 X1300 X1301 X1800...
Acer aspire x1301 u9052 wont boot
Im not 100% sure about this but may i suggest you change the CMOS battery on the Motherboard, there is a chance that it is flat its a very common battery that you can purchase from your local store, but just change that and let me know what happens
Jun 19, 2010 | Acer Aspire X1301U9032 (PTSCM02007) PC...
Acer Aspire M5100 shuts down randomly. Sometimes lots of programs running, sometimes none. Fans have always been loud, and they still are. I don't know how to troubleshoot, I am a graphic artist and I need...
Would need more detail but sounds like it is a problem with your processor overheating because of ur fan situation. To be sure of this download a program such as speedfan to gauge your temps.
Mar 18, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
Acer Aspire T135 PC Desktop Logo
956 people viewed this question
Lee Hodgson
Lee Hodgson
Steve Sweetleaf
Steve Sweetleaf
Gustavo Ortiz
Gustavo Ortiz
