I just tried to upgrade to a 4GB card, and my Canon PowerShot SD500 is saying that the "memory card is locked" even though it isn't. Is this card incompatible with my camera?
I've come across many people who say their card isn't locked only to find that the slide switch on the side of the card is indeed in the locked position. Check yours.
The SD200 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in this camera. You need to use SD cards, 2GB and smaller.
According to the specs on Canon's web site, the IXUS 700 works with SD cards, not SDHC cards. SD cards are limited to 2GB in size (there are rare 4GB SD cards, but they tend not to work in SD devices).
Of course, it's your call as to how definitive any manufacturer's web site touting their product might be.
The Canon A430 uses MMC and SD cards. While SDHC cards will fit into the slot they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
You may be restricted to using only SD cards, and many 4gb cards are actually SBHD. My sister had this problem with her camera and by putting in a new 2 gb SD card, her camera worked fine. You may need to shop online in order to find an SD card, but they're widely available online. It costs about the same for 2 2gb cards as one 4gb even though they aren't as convenient.
Maybe you could try to format the card in the camera. If that doesn't work, try formatting it in the computer. (The card alone, not the camera connected to the computer) Otherwise I think it's broken. Do you use a micro/mini SD adapter? If the contact is bad, it may tell you "Memory card error" and "card locked" at the same time. Check the contact.
Sorry, but your camera was designed before the 4GB SDHC card came out. Although they look exactly the same as a standard SD card, they are not. Your camera can only use standard SD cards (2GB or less).
There are regular SD cards and high-capacity SD cards (HCSD). Some devices are not compatible with HCSD cards. It sounds like your camera is not compatible. You may still be able to purchase 2G & 4G regular format SD cards that will work fine.
The A540 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in this camera. You need to use SD cards, 2GB and smaller.
The ixus 700 is only specified to be compatible with SD memory cards (and MMC cards). The protocol for SD cards only covers up to 2MB. Cards of higher capacity are the SDHC (high capacity) protocol, but this protocol did not exist when the ixus 700 was introduced. As far as I can tell, there is no way to upgrade to be compatible with the newer protocol.
Is it an SDHC card?
