2wire (1000-400108-001) Router Logo
Posted on Jan 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Linksys 2 wire router. My DSL connection
I have a Linksys hardwired router. My DSL connection coming from the wall is fiber optic service. When I am on my company VPN using Outlook, the connection constantly drops. Do I need a new router? Mine is about 3 years old. HELP! Thanks!
Anonymous
Level 2:
New Friend:
  • Expert 78 Answers
  • Posted on May 02, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
78
Questions
0
Helped
26168
Points
175
It could be a lot of things giving you trouble
fisrt check if your connection is droping from the isp
if so contact isp
second check lights on modem such as power dsl and internet
3rd think of a modem remplacement
Hello,i have a problem with my linksys Etherfast cable/DSL router The power light will not stop flashing no matter what i do
That's because a stable connection is not being determined by the router. Call up you're ISP and inform them about the issue. There is probably a lot of distortion on you're phone line ! Ask them for a fiber optic upgrade !
Hope that answers your question !
I lost my setup disk, and I can't use it without it.
If you lost the setup disk of your router, you can set it up manually.
First is you need to find out what type of connection is your ISP, cable, dsl, or fiber optic etc. If it is cable or fiber optic, it's a plug and play. If it's dsl, you need to get your username and password from your ISP.
My usrobotics wireless router 5465 shows wireless internet connection in my vista laptop but I cannot acces internet. How this can be fixed.
You are connecting to your local network, but it doesn't sound like the router is making the connection to your Internet service provider. What sort of Internet service do you have? (ie. cable, DSL, fiber optic?)
If you connect your computer to the router with an Ethernet cable do you get the same result?
Need to hookup with 1 wireless and 2 hardwired computers
Here you go, step by step:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4055&p_sid=UcVbWIYi&p_lva=3967#
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
Thanks, Joe
Trying to hook up a Linksys Wireless -G 2.4ghz Broadband Router. Want to link my dsl and my xbox and then later down the road a lap top. Dont know where to begin. Do I take the phone line thats inthe wall...
first you connect the wire from the wall into the wan port in the back of your dsl modem. next you connect the outsource wire from your dsl modem into the wan port on your router. next put another rj45 wire into the number one port in the back of your router and the other to your computer. put another wire into number 2 and then to your xbox. everything need to be unplugged while you are hooking it up. once done power cycle...meaning plug up the dsl and wait for the lights to stay lit. then the router. the start your computer. if you want to go wireless just get a usb wireless network adaptor and there you are
2answers
Limited or no conectivity
hello!
-- are you connected hardwired or wirelessly to the router?
-- do you have other computer working on your network?
-- what is the operating system of your computer?
Linksys wireless connection keeps getting dropped
From you DSL modem or broadband router, what is the next device connected?
2helpful
2answers
How To Set Up PPPoE DSL Connections with a Linksys Router
This article describes how to manually configure a Linksys Router for broadband DSL that uses PPPoE (Point-to-Point Protocol over Ethernet) for authentication. For automatic configuration options, please try: 1. Linksys Easy Connect (see Answer ID 1650 for more information), or 2. The Linksys Setup Wizard CD-ROM software that came with your Linksys Router. Simply insert this CD-ROM into an online computer before connecting your Linksys Router, and the Wizard will provide step-by-step instructions on how to install and configure your router. If you are unable to set up your Linksys Router by using one of the above options, use the steps below to manually configure your router. NOTE: It is recommended that you print this article for offline reference. STEP 1: Before You Begin In order to set up your Linksys Router, be sure to first have the following: 1. A Linksys Router. 2. A DSL modem. 3. A working computer that can be wired in directly to the router for initial configuration and testing. 4. Two (2) standard Ethernet network cables. Linksys Routers come with one (1) standard network cable that you can use. 5. The PPPoE DSL username and password assigned by your Internet Service Provider. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address ([email protected]). If you are not sure what your username and password are, contact your Internet Service Provider for more information. STEP 2: Check Your Internet Connection Before installing your Linksys Router, it is important to first verify that you can successfully access the Internet by connecting directly to your modem (without your Linksys Router installed). 1. If you are connecting for the first time, follow the instructions provided by your provider to set up your modem and computer for online access. 2. Verify that you are able to access the Internet without any problems. If you are not able to get a connection, contact your Internet Service Provider for assistance. When you are able to access the Internet using your modem, continue to Step 3 and proceed with the installation of your Linksys Router. STEP 3: Connect the Hardware Follow these steps to connect your Linksys Router to your modem and computer. 1. Shut down your computer and unplug the power cords connected to your modem and Linksys Router if they are currently powered on. 2. Disconnect the network cable that connects to the back of your computer. 3. Connect the network cable that you just removed to the Internet port (or WAN port) located on the back of your Linksys Router. Your modem should now be connected to your Linksys Router. 4. Connect a second network cable back into your computer (into the same port that was disconnected in #2). 5. Connect the other end of the second network cable to one of the numbered ports located on the back of your Linksys Router (labeled 1, 2, 3, 4, etc.). Your computer should now be connected to your Linksys Router. The following diagram shows how your network should be connected. Verify that your connections are correct, and continue to the next step. 6. Plug the included power adapter into the router?s Power port. Then, plug the other end of the power adapter into a nearby electrical outlet to supply power to your router. 7. Turn on your computer. Do not turn on your modem at this time. Only your router and computer should be turned on for Step 4. STEP 4: Configure the Router Follow these steps to configure your Linksys Router. 1. On the computer that is connected to the Linksys Router, open a web browser such as Internet Explorer or Netscape. 2. Type http://192.168.1.1 into your browser?s Address or Location bar and click Go or press the [Enter] key on your keyboard. The IP address 192.168.1.1 is the default IP address of Linksys Routers. 3. A user name and password prompt will appear. Leave the user name field blank (empty), and type in admin (lowercase) for the password. The password admin is the default password of Linksys Routers. NOTE: The following username/password prompt screen will vary by operating system. 4. Once logged in, the router?s web-based Setup utility should load. In the section labeled Internet Connection Type, or WAN Connection Type depending on router model and firmware version, select the PPPoE option on the drop down list. Click here to view what an older Linksys router interface looks like. 5. Once PPPoE is selected, enter your PPPoE DSL username and password provided by your Internet Service Provider into the router?s User Name and Password fields. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address ([email protected]). If you are not sure what your username and password are, contact your Internet Service Provider for more information. NOTE: Be sure to
Top 2wire Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
