Question about Northern Tool 10,600 BTU Radiant Kerosene Heater
Burning correctly I have, new purchase within the last 30 days, Dyna-Glo RMC-95-C6. Right after the setup I noticed that the suggest highest flame (height) could never be reached and even the slightest counter-clockwise turn turned it below the edge. The wick is at the correct height and it has been dry-burned numerously. The kerosene (K-1) works fine in the other 'kerosene heater' I have and I always purchase same from the same supplier. Once it has been burning for an hour-or-so the flame drops below the minimum with the adjuster turned fully clockwise. Help.
Posted by buzzmarsh on
Anonymous
    New Friend:
  • 77 Answers
Since the unit is new I would contact customer support at the we site or by calling phone number in owners manual.
Posted on Jan 22, 2010
1 Related Answer
Anonymous
SOURCE: Changing Wick in Kerosene Heater
http://www.bobvila.com/wwwboard/messages/284598.html
Posted on Nov 20, 2008
How do you dry burn dyna glo rmc 95-c6
A "dry burn" is when the heater runs out of fuel and the tar buildup on the wick is burned away. This operation should be done outside in a covered location. It should only be necessary every seven days of 24/7 operation.
Dec 16, 2014 | Heating & Cooling
I just replaced the wick, cleaned up the heater and filled with new K-1 kero. The heater (Dyna-Glo RMC-95-C7) is emitting black smoke worst than ever. The wick is burning a little unevenly.
Either the wick was improperly installed or you may not have allowed enough time for the wick to soak in the kerosene and become evenly distributed. Check the placement of the new wick and allow time (several hours) for the wick to absorb the kerosene.
Jan 31, 2011 | Dyna-Glo RMC-8001SS Heater
Dyna glo RMC 95 C6 kerosene heater, BRAND NEW. Wick and flame seem very low. At Max the wick height is 3/8(suggested height by manufacturer), flame is quite low, and not very hot at all
1. Check to make sure you using fresh clean kerosene fuel. 2. Make sure you fill the heater and let it set for at least an hour, 2 hours is better. 3. If either of those solutions don't fix the problem, return to the store.
I have the same heater and just changed the wick. When working correctly, it should be so hot that it's uncomfortable to hold your hand 2 feet over it.
Jan 01, 2011 | Heating & Cooling
Have a Dyna Glo RMC-95-C2 and I can't get it to lite.
You have to change the batteries.. the manufacturer shipped it with **** batteries.
also take it apart.. very simple and clean out any soot..
Soot will cause heavy smoking...
The wick should last more than a year ....
Dec 14, 2009 | Dyna-Glo RMC-8001SS Heater
What wick do i need for dyna glow rmc 95 c6?
you need wick part #3C, you can get it at portableheaterparts.com or call them at 1-800-362-6951.
Dec 07, 2009 | Dyna-Glo Heating & Cooling
I have a dyna-glo rmc-95-c6 heater it smokes and makes an awful smell  the flame is not as high as shown in the owners manual  what can i do to fix the problem?  thanks
You can buy the wick at Lowes. I have the same heater. They where $10.00 each so I bought 2. I will go back and stock up on them. Package Number DH-145 It will say it will fit RMC-95C thur RMC-95C7
Jan 24, 2009 | Heating & Cooling
I need to buy a replacement wick
You can get them at Lowes for less then $10.00 Number DH-145
Dec 23, 2008 | Dyna-Glo RMC-8001SS Heater
Northern Tool 10,600 BTU Radiant Kerosene Heater Logo
277 people viewed this question
Top Northern Tool Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Northern Tool Heating and Cooling Expert? Answer questions, earn points and help others
