Pride Victory 4 Wheel Mid-Size Electric Scooter  Logo
Posted on Jan 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a old pride victory 3 scooter working well what is the minimum charging time /how much for a replacement battery/s and how long do they last thanks
littleone121
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on May 06, 2010
littleone121
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
21323
Points
45
It is best to let it charge at least over night, longer if it hasn't been used for a while. It is also good to give them a long workout (Don't completely flatten them though) at least occaisionally. If they get regular and thorough use they will last longer, but extra weight like shopping, or lots of steepish paths will flatten them a lot faster. They are only supposed to last a couple of years, but will go longer if you look after them.
One of the most important things is to find a supplier/repairman you can trust. These are, after all your legs or mode of transport you are talking about.
A
Anonymous
Walmart for batterys deep cycle batterys need to be run down before charging check charing procetures in google
Rob Hill
Level 3:
  • Pride Master 1,480 Answers
  • Posted on Jan 15, 2010
Rob Hill
Pride Master
Level 3:
Answers
1480
Questions
0
Helped
517726
Points
3838
The minimum I would say, is about 8 hours, best to leave them on charge all night so they are fresh and will give max power in the morning, keeping them charged on a regular basis will help prolong the battery life, I had batteries last me two years used every day, I believe you get what you pay for in batteries for example MK are very good but can be pricey.
Regards
GeWiz.
1helpful
I have new batteries two weeks old. They now will not charge properly. could it be the charger? This is on a victory 3 scooter
Did someone qualified tell you that you needed new batteries?. I would go back to the battery supplier & go from there.ALSO,if you still have the old ones can they be tested too.Ask them,i hope this helped.Colin
Pride V10 ****** wont hold a charge. It runs out of power afetr 10 minutes,
hi, well how old is the V10 ? please remember a pair of batteries is only as good as the charger...
Regards
Rob
www.gewizrepairs.co.uk
I have a victory pride mobility scooter the battery is fully charged and it won't run I tried to reset but nothing worked
Have the controller module checked. You can also download the service manual from Pride's website. It has a lot of information in it as well as a complete wiring diagram.
My pride mobility victory scooter will not charge
You must charge each battery individually with an automotive NON automatic style battery charger until each battery has at least 10 bolts each. The scooter charger cannot pull up a battery with less than 10 volts.
Scooter only moves a short distance, then stops?
If the scooter in question is a Pride Victory with on board charger ? ( you plug a mains lead into it ?) now what happens with this particular scooter as the charger starts to fail, it's not charging the battery correctly, if you have access to a multimeter DC setting , check the voltage from one of terminal of the battery to the other terminal of the opposite battery, now it should read at least 18 volts , 0 volts then you need to change from one terminal to the other and same for the other battery ,, now if it below 24v that's the problem because as soon as you put it under load the voltage drops to under the minimum working voltage for the controller , hope that makes sense so other-words you need to replace the on board charger , contact me and I show you a way to do this cheaply...
Regards
www.gewizrepairs.co.uk?fixya
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
2answers
My scooter says its fully chrged but its not. this happens once in awhile, any suggestions?
your batters have lost their charge at some point in time. These gel batteries, if they ever set for a long time with out recharging, or arn't recharged daily with daily use, will seem to be charged. but arn't. their expensive but I've seen batteries last over 5 yrs when taken care of properly.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
