Model: LER3624EQ1
The dryer does not produce heat but everything else is normal. Why?
Remember when the thermal fuse goes something caused it. Check your opreating thermostat if the fuse is bad.best to change both.
There are three things to check out if your dryer is not heating.
The Element
The High-limit
The Thermal cut-out
Check out this "Tip" it goes over all the details for you.
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
Fixing your dryer is not that hard. The total cost of all the parts is not that high and while you have it apart, change everything. All three parts should cost you around 100 bucks or less. Shop around.
Heatman101
Probably the thermal fuse or heating element. Either way far cheaper to fix than replace. Click this link http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat for more details.
Probably a bad heating element. There are a few different styles, you'll just need to lookup your model number on an appliance parts website, find the right part, and then do a quick search on replacement. There are probably ten or fifteen websites that have instructions to replace heating elements.
Here's one where you can buy the part, the element is part number 17.
http://www.appliance-parts-warehouse.com/whirlpool-parts/Whirlpool-Dryer-Parts/Whirlpool-Parts-LER3624EQ1/Whirlpool-Parts-81777.cfm
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
