Question about GE Energy Star WCVH6260F Front Load Washer
There is a red padlock on the lcd. washer will not do anything
Posted by tim5141 on
Jeff Rockwell
  • 5,911 Answers
If the model number is correct, this is a Safety Lock feature that allows the consumer to lock the control panel to prevent any of the front panel selections from being manipulated. This is used primarily to prevent small children from accidentally turning the washer on.
To turn the feature on/off, press and hold the LOCK button for 3 seconds. The Lock icon will go out when the washer is unlocked. These instructions are on Page 7 of the owner's manual. If you do not have an owner's manual, you can download or print a FREE copy at managemylife.com. Just type in the model number under the "Manuals" link and the owner's manual and installation manual is available in a .pdf (Adobe) format.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Jan 15, 2010
GFWH1200DWW GE front load washer won't unlock red lock showing
From an article I found online:
See if manually opening the door will reset everything. Unplug the washer and remove the lower front panel like you're going to clean out the drain catch. Once you remove this panel you can reach up behind the upper front panel and pull down on the small plastic pull tab attached to the bottom of the door lock assembly. This will manually unlock the door so you can open the door.
Now once you have the door open, plug the washer back in and see if you can start another cycle.
Mar 06, 2016 | GE Washing Machines
Cant get sky email
red padlock is the web page is unsafe. you may have something blocking your internet access to sky. something like java not working correctly. try a different browser.
Mar 06, 2018 | Archos 704 WiFi Digital Media Player
A red padlock symbol is showing on the panel of my WCVH6800 front load washer. I can't change any of the wash settings. How do I fix this?
Here's what the Padlock represents:
Lock Function
You can lock the controls to prevent any selections from being made. Or you can lock the controls after you have started a cycle. children cannot accidentally start the washer by touching pads with this option selected.
To lock the washer, press and hold the DELAY START button for 3 seconds (on some models use SIGNAL button). To unlock the washer controls, press and hold the DELAY START button for 3 seconds. The control lock icon on the display will light up when it is on.
NOTE: The POWER button can still be used when the machine is locked.
Jun 28, 2011 | General Electric WCVH6800J Front Load...
Lcd dislays lock padlock and none of the buttons
To Unlock the buttons, kindly follow the instructions on the Dell support page by clicking this link.
On the page which opens, scroll down to the OSD settings section.
Thanks for using FixYa.
Jul 12, 2010 | Dell E156FP 15" LCD Monitor
Just purchased a verbatim 4gb usb drive in a plastic case with a little red and green padlock on the side of the case, how do you open it??
From what I have seen on Google images there should be a plastic slider down the middle that needs to be moved to the Green padlock. The Red padlock will mean data locked the Green open.
Jan 02, 2010 | Computers & Internet
Red padlock on sreen why i have a blue screen and no controls work...red padlock top left of screen
Check your remote to see if it has a simular red padlock symbol (button) if so press it.
Nov 05, 2009 | Televison & Video
Control locked
hold the padlock button for 3 sec, if that doesnt work replace the user interface
Jun 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Padlock sign has turned red and washing machine doesn't work
This is Joyce
try to unplug the washer for 1 min and replug back hopfully that will do the trick. if not go online to brandt.com and put in your model# and download you model# and download your manual to get information on your model to unlock.
hope this helps
thanks
joyce
Feb 04, 2009 | Brandt WFH1276F Front Load Washer
When we turn the zone tv on a padlock shows and we can't do anything else
I see you did not list the make (Zone??) and model of the set; advice is going to be slim from anyone since these features are often brand-specific. I suggest you search out the maker's website and email them for help.
Sep 29, 2008 | Televison & Video
Red light padlock symbol? what does it mean
the padlock led indicates that bthe door is open or poss interlock fault, however since you said it now trips fuses, IF you are not electrically minded call an expert something could of become disconnected or moisture could of got into the machine and blown the module
Jan 09, 2007 | Indesit WA 125 Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
