If it's a user password and not the administrator, you can go in to "User and Account" settings as the Admin user, choose "Manage another account", and select the option to "Change password".
Other than that, you could burn a CD of the Offline NT Password and Registry editor from http://pogostick.net/~pnh/ntpasswd/ and boot into that. You'd be able to blank any password on your system, but any encrypted data belonging to that user would be inaccessible until the password was changed back to what it was originally.
go to http://www.telecom.toshiba.com/ and download a users guide. I suspect you want to do this for VMail. So look for the Stratagy VM users guide on this site.
You'd have to reboot the phone, and press the white dot 'Program'
button within 30 seconds of reboot, then use the arrows to scroll down
through the menus to Advanced settings, and find Eeprom reset to default, and choose that. *Note- This will reset all values of the phone. If it's Ethernet Only, it's
fine. If the phone is using a Static IP, it will also clear the IP
addressing on the phone*
If you are talking about resetting the phone from a user profile perspective it is different. You can reset the voicemail password under the system maintinence, password administration and select user password in the drop down box. After the password has been reset (to the extension number) they can log in and change the recordings and password. You will also need to then go to the users tab and change the name.
if you are refering to a password click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password also if you are not the computer administrator and have not assigned a bios password during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there alsoclick start control panel user accounts on the users tab,click the name of the computer administrator you must have full control can change the password there
Generally your Code will be 12345[if it is not Changed].you can Change your User Password by Entering Old Code.If you forgot your Old Code you may need Unlock tools to Unlock it.unlocking tools are Expensive[Avoid Purchasing of Tool for Self use.Because it is changing tool and may become useless].You can Unlock it by giving in a Shop for Small Cost.....Dont forget to Rate...
