Display is blank ... while pressing the ON key tic tic soud is coming with green blinking light ,i opened it and found that its half part of the tube connector (gh027 01500528)is fully burnd out ....... is it possible to replace the board .. if so how much it will be??? do i need to cahange anything else?/??? thank u
Configuring codes: Turn on the component that you want to set up. 1.Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds. 2.Release the component key. 3.If you are programming the DVD or CD device press the "action" key. The red indicator light will come on. 4.Within thirty seconds, enter in a 4-digit code number. The component key lights will blink with an upward motion when a code has been successfully entered. In this case proceed to step #5. If the code has not been successfully entered, the componment lights will not blink. In this case return to strep #1 and start over. 5.Test code by pressing "Power" key. If the component turns off, you've got the right code. Follow the same instructions to set up your other components. If the component doesn't turn off, return to step 2 and use the next 4-digit code listed. Auto Code Scan: The Auto Code Scan feature allows you to set up your components without having to enter in code numbers. The Jensen will do the work for you! 1.Turn on the component that you want to set up. 2.Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds. 3.Release the component key. 4.If you are programming the DVD or CD device press the "action" key. The red indicator light will come on. 5.Press "0" - "9" The green light will blink as codes are sent. 6.As soon as the remote turns your component off, press the "action" key. The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. 7.If none of the codes turn your component off, return to step 2 and start over.
Turn on the component that you want to set up. In the code listing
find the 4-digit code numbers for your component brand.
Note: If none of the codes turn your component off, try the Auto
Code Scan function.
Auto Code Scan:
(It may take a few minutes to find your code using this method.)
sent.
"action" key. (You have 1 second in which to press the "action" key to
save the code.) The component key lights will blink with an upward
programmed. To find that code, proceed to Code Readback.
Code Readback:
Press the "enter" key.
Count the number of times the green light blinks. There
will be four numbers, separated by a two second pause. The red light
will tum off after the remote is finished reading numbers back. Make
sure you write the code number below for future use!
Multi-Component Power On/Off:
The Jensen remote has the ability to turn On/Off multiple components at
once. When you perform the following steps, you can turn On/Off the TV,
VCR, Satellite, Cable Box and Audio Receiver.
Press the "action" key.
Press the "power" key.
Note: This feature does not work for DVD and CD.
Volume Priority Punch-Through:
When you press the volume keys on the remote they will control the
volume on your TV. If you have a home theater system and want the volume
keys to control your receiver only, you may set your volume priority to
the receiver.
Hold the "RCVR" key down until the green indicator light comes on.
The green light should come on after about 3 seconds.
Press "RCVR" key.
Press "Vol+" key. To disable the volume priority you have
to set and return to the default.
To change back to TV priority:
on. The green light should come on after about 3 seconds.
Press "RCVR" key.
Press "Vol-" key. The volume priority will now default to the
TV volume.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
Find the pink Clear button on the Control Panel of the WorkCentre.
Find the button below the word Auto.
Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto]
NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
Press the green [Start] button.
Press the pink [Clear] button two times.
The WorkCentre should now warm up and come to ready.
If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
tough call. from your decription it could be the tubes the pulsating. but if i had it in the shop i wwould first look at the convergence curcuit. the fact that the on screen display come up in colors inidcates convergence problems. you might have multiple component falure there. as for cost it could be diddicult to say. average repairs like this barring piture tube problem at my shop run 200 labor and about 150 parts. this is just for convergence cuircit rpair
NOTE:
Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
H2 or 2H is related to a fuser under heat or overheat.
Try this first,
If this does not clear the problem the fuser will need replaced.
