I don't seem to be able to get the bulb out. There's a cylindrical metal frame surrounding it. I can move the bulb in all directions. This is standard ''new construction'' recessed lighting. Is there a trick to changing these bulbs?
I'm pretty sure you just swing open the lamp cover and the bulb will be right there. It just pulls out.
This is a halogen bulb and will be spendy (over $20).
# 1 Unplug the microwave from its electrical outlet. Never service an electrical appliance while it's plugged in. # 2 Remove the screws that hold the outer shell onto the microwave chassis. Often the screws are on the bottom or back of the microwave. Use a Phillips screwdriver or Torx driver to remove the screws. # 3 Lift the outer shell off the microwave chassis and locate the box that houses the halogen lightbulb. In most cases, the box is metal. It may or may not have a lid on it. If it has a lid, loosen the tabs and pull off the lid. # 4 Unscrew the halogen bulb and replace it with a bulb rated at the exact same wattage. # 5 Place the cover back onto the box if necessary and place the shell over the microwave chassis. # 6 Secure the shell to the chassis with the original screws and the screwdriver or torx driver.
lid.
5
6
When you open the door on your microwave, it sends an electrical current to the halogen lightbulb mounted inside the microwave. The signal turns on the light and illuminates the inside of the microwave. In addition, while cooking your food, the light illuminates so you can monitor the condition of your food while cooking. While the bulb generally lasts a long time, when it burns out, you must service your microwave.
It sounds as if you may have higher wattage bulbs and/or the wrong type of bulb installed in the can fixtures than the recessed cans are rated for.
When the wattage of the bulbs is higher than the rating of the fixture, and/or the wrong bulbs are being used, the recessed can's thermal overload device will shut off the light, to prevent damage and a possible fire situation.
It is unlikely that you've got a faulty dimmer, since you state that not all of the lights go off at once, thus it can be narrowed down to each can and thus the thermal overload being the culprit.
I would suggest you look inside the recessed can light fixture and determine what the maximum wattage bulb you can use, (60, 75, 90 watts, etc.) and use the next lower wattage bulb instead. I also install only Halogen bulbs in recessed cans, (they have a flat lens vs. a rounded bulb lens area like PAR type bulbs). Halogen bulbs are also the most efficient incandesent bulb that provides the whitest light possible and directs more light (and thus heat) downward away from the recessed can.
I avoid using a standard light bulb or PAR type bulbs in any recessed can fixtures as they tend to heat up quite a bit and cause the thermal protection to trip frequently.
As a Master Electrician that has installed literally thousands of recessed fixtures and dimmers, I can say that my customers prefer the Halogen light over standard bulbs and they last longer too.
I hope you find this Very Helpful and best regards!
Mine is installed also, and I've had to replace the bulb twice. I wised up the second time and installed an access hole where I can pull my microwave out about 6" and access the bulb. I use a 35 watt 120v halogen bulb, with a GY 8.6 base, Lowe's part number 15797. If your's is different, the specs will be stamped on the metal beside the reflector when you remove the sheetmetal. You have to remove the microwave completely from the cabinet and remove the sheetmetal case that surrounds the entire unit. You can then access the lamp socket by looking in from the top. The first time, I took out the reflector with the socket. The bulb can be replaced by removing the two small screws adjacent to the socket on top of the reflector. My access port is a hole cut into the top. I cover the hole with a piece of sheetmetal and two sheetmetal screws. Seems to work just fine. If you do decide to cut a hole, do so with the metal enclosure off and away from the microwave to avoid getting any metal shavings into the machine!
Regards! --W/D--
Hiya...
When this happens, it means one or two of the halogen headlight bulb(s) has been burnt-out.
Do this quick and easy self-test:
Turn on the headlight switch to LOW and see if you see one (or none) turns on...you'll know one or two lightbulb(s) need to be replaced....this is why the green headlight logo flashed to tell you that a bulb has just burnt-out.
You'll need to remove the 4 black plastic clips that holds the top grille bracket frame onto the top metal frame that's facing the top radiator area.
If you know which headlight's bulb need replacing, just remove the 3 bolts...two are on top and one is by the side (close to radiator area)
Then you pull the grille toward you gently to allow your hand to access behind the grille and headlight area to reach the white socket that's connected to the headlight bulb.
This requires some patient as it's a tight area for your fingers to wiggle the socket off.
When the new lightbulb is installed, the green headlight logo will appear in the instrument panel when you start the engine.
That'll help!
