Televison & Video Logo
Posted on Jan 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix my 51" big screen magnavox tv?
My 51" big screen Magnavox tv looks like a 3D movie and is all blurry how do I fix it or can a tv repair shop fix it and how much will it cost?
Todd Thornton
Level 2:
Scholar:
  • Expert 101 Answers
  • Posted on Jan 15, 2010
Todd Thornton
Expert
Level 2:
Scholar:
Answers
101
Questions
Helped
45603
Points
214
You can use the red and blue glasses to see 3d. looks cool. But you can have the convergence ic's replaced.And that will fix the problem. Usualy $225-300. At a shop. PIA to do it yourself. That is why it costs so much.The ic's have several pins to solder. and it is not easy to unsolder. pluss you have to disconnect all the wires from the board to take it out.
Simple fix. just alot of work to get it done.About 2-3hrs.for a tech to do. After you replace them you have to re-align the colors. If you get it done,ask about replaceing the coolent as well. Usualy the blue goes bad. Gets blurry,or blue haze around words.
and it should be good as new.
Philips Magnavox 9P5031C 50-Inch Projection TV has a red/orange blur the whole picture is blurry
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
What causes a blurry screen? and what is the fix?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
My picture is blurry and green
  • Screen looks 3D
69189a5.pngSOLUTION
Picture looks 3d and a little blurry
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Lines, a little blurry, a little movement
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
I have a Phillips Magnavox HD Tv Rear Projection Television and the picture looks greenish and reddish and is blurry on the text of the screen? please help.
Projection TV2_bing.gif sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Wavy color lines on left bottom corner. letters somewhat blurry.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
2helpful
I have a 51 inch magnavox projection tv, the color started with a blue tint but now the red and green has gotten weird also. the screen is starting to have half circle or look bent also on top and bottom...
Ur convergence it dead,Know how to solders?Can buy a convergence kit,replaced what in the kit.Tries websites.Tv repair World.com,Tvrepairkits.com.To repair ur self.Cost u about $300 to repair by the the shop.
2answers
Colors on tv are blurry, almost like when you watch a movie in 3-d, the red and green colors seem to go around the main image
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
3D blurry picture
The convergence ICs and resistors need replacement. The DPTV305-345 convergence repair kit works for most Phillips rear projection Tvs. The kit contains the two ICs 12 resistors and the CD with detailed instructions
http://www.tvrepairworld.com/
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
