Question about LG CF360 Cell Phone
I have a LG CF360 and I am trying to insert the memory card, but I can't get it to stay completely inserted.
Posted by ruthalon2 on
Anonymous
    President:
  • 3,278 Answers
Hello.
Insert the memory card into the slot until the memory card is fully inserted into the slot. Note that the gold connectors must be facing down and inserted first into the memory card slot.
Hope this helps.
Posted on Jan 15, 2010
Cant format my 2 gig memory card to my lg qwerty ks360 keeps saying enter security code only works with 0000 then switches itself off???
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • 0helpful
    How do i format a memory card for the lg vu 930
    Hi there
  • 0helpful
    I just received an LG CF360 in the mail, inserted my pin card, and fully charged the phone. The box didn't come with a memory card so I wasn't sure if that was necessary to power on the phone, as it won't...
    No Memory cards do not have anything to do with your phone working. All you need is your SIM card (if your phone comes with one). You can use your old SIM card as well as long as it has not been deactivated by provider.
    5helpful
    2answers
    WHY DOES MY PHONE SAYS INSERT SIM
    try taking SIM and battery out placing it back in an powering on.
    If you try this and it still does not work you may need a new SIM card. Take it to a local dealer they should have a new SIM they will put your number on it and you will be back in business.
    If the new SIM doesn't not work you will now know it is your Phone, which means time for a new one.
    good luck
    Just got a new lg cf360, charged the battery, inserted the sim card and tried to turn phone on. The phone will not turn on. What have I missed??
    Same thing happened to me. The insurance sent me two LG CF360's and neither will turn on. They are now sending phone 3 to try. I was on with AT&T tech support for an hour and they couldnt figure it out. Did you ever get yours on?
    Nov 06, 2009 • Cell Phones
    I just received my new lg cf360 in the mail, inserted my micro sd card and it does not work, says "card not ready!" I previously had the sd in my blackberry pearl and it worked fine.
    I ended up figuring it out myself. I inserted my sd card in my pc, copied everything into a folder, went in my computer & right clicked my sd card, (labeled blackberry) formatted it. Reinstalled my stuff from the folder I copied, and inserted it in my new phone. Voila!
    Only problem now, my ringtones do not work, says file too big. & The phone tends to occasionally have a brain fart and lock up or erase my info. This is a cheap crappy phone.......
    I'm tring to download the phone numbers from one phone to the other, old phone is a Nokia model#6030. But the new one is a LG CF360 and I don't know out to do it.
    its simple try to save ur contacts in sim memory so that when ur inserting ur sim in ny new mobile jst copy the sim contacts......
    1helpful
    4answers
    How do I format a memory card to work with this phone?
    dear to format a memory card just connect it with PC ,keep the cell in data storage mode & right lick on the memory card there will be a option for format ,format it,it is similar as we format our drives
    Memory card
    it only supports micro sd and not memory card or mmc
    LG CF360 Cell Phone Logo
    Top LG Cell Phones Experts
    Steve Sweetleaf
    Steve Sweetleaf
    nexrad_chris
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
