Samsung VR3607 VHS VCR Logo
Posted on Jan 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i run the cabel in to the vcr and then out to the tv I can only get channels 1-13. How do I get the channels above 13?
Anonymous
Level 3:
  • Master 603 Answers
  • Posted on Jan 15, 2010
Anonymous
Master
Level 3:
Answers
603
Questions
0
Helped
234580
Points
1582
Is VCR cable ready?
1helpful
Bought new samsung dvd/vcr. have an older admiral tv with just a cable hole. this is the second tv on a dish network, so this tv only has a cable, the box is in the living room. so how do I hook this...
The easiest way to make it work is to:
1- run your cable into your new VCR to CATV IN.
2-Your VCR should have come with a short length of cable. Connect it from the OUT jack to the TV.
3- Set the TV to either channel 3 or 4- you need to check the VCR manual to see which channel you have to use. Some VCR's have a small switch labeled "channel select"- if so, set it and your TV to the same channel... your choice.
4- Leave your TV on the channel you set above all the time. You will now change your channels using your VCR. You will be able to record whatever you are watching.
How do I hook up a VCR? There is only a portal for the cabel on the back. mpartridge
You will need to have a VCR with a cable connection on it. You will need to remove the cable connection(if connected) on the TV and connect it to the "cable in" connection on the VCR. Then the coaxiel cable will connect from the "cable out" connection to the cable connection on the television. You will then need to turn the channel on the TV either to channel 3 or 4. Then turn on the VCR and you should be able to watch a tape on the VCR. If your VCR does not have a cable connection on it then you will need to buy an adapter that turns the cable connector into RCA style jacks.
Loewe 30" tv turns on, message "no signal"
first thing I would do is to make sure your cable box is turned on. if not fixed, make sure you have the correct input. this can be done by viewing all the inputs that the tv has by pressing the input button on your remote until you find a picture. if it is still not working, make sure you have you cable run right. there should be one cable running to the cable box and into the port labeled antenna or input, then anouther labed cable running from the output port to the tv. there might also be a vcr or dvd play inbetween. if that is the case, the cabel running from the cable box should go to the input of the vcr or dvd play and the output line should go to the tv. any equipment inbetween the cable box and tv should be turned on when viewing you cabel tv. you will also have to make sure that any equipment inbetween is running off the cabel input.
4answers
I am having difficulty when I try to program the VCR to tape a TV show that I am not watching. When I go through the nine steps that are outlined in the manual on pages 24 and 25 the TV will tape for me...
if you are useing a cabel box you need to split your cable before the cable box with a two set coupler and run the second cable line to the VCR input and this should solve your problem. if you want to record the chanels from your cable box and not watch a diffrent chanel you can leave it hooked as is and select the chanel you want to record with your cable box tunner and leave it turned on, set the vcr to record channel 3 or 4 which ever is the channel you leave your tv tunner on and record that way.
2answers
Parental control codes
Hi.
Please state make & model of your tv set ?
http://dysonmanuals.llc.nu/
Chris.
Sharp tv/vcr combo
go to menu go channel auto search
3answers
Ilo dvd player wont search high channels
At a guess the device will only find channels it can detect. So what is your connection antenna or cable If antenna then all TV is line of sight and directional If cable - only the channel's the cable co supply will come down the wire.
Intermittent snowy pictures under Channel 51
Probably needs a new tuner or something associated with the tuner.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
