Vizio L6 20.1 in. HD-Ready LCD Television Logo
Posted on Jan 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where to find a lcd panel for a vw26lhdtv10f? i have a broken lcd screen everything else is good.
Anonymous
Level 3:
  • Master 2,926 Answers
  • Posted on Jan 15, 2010
Anonymous
Master
Level 3:
Answers
2926
Questions
0
Helped
1004695
Points
9623
How replace lid on 1001 px
Disassemble the power panel first to expose the lcd connector and otherss, then remove the screws that holds the lid to take everything apart for replacement of the lcd panel.
2helpful
Broken Screen, Sanyo DP42647
If the LCD panel has broken and the tv is not covered by accidental damage repair insurance, then your only realistic option is to sell your tv as a spare parts donor and to buy another.
The LCD panel is overwhelmingly the single most expensive component of your tv; it actually costs more to buy a new panel than it does to replace the complete tv. If you do have insurance cover the company will usually just buy you an equivalent replacement model rather than repair yours.
Sorry, but not everything is realistically fixable.
2helpful
Dell 1545 laptop with white LED screen on start up. Works fine when connected to external screen via vga connector. Everything else works ok. Broken & remade connections between mobo & screen = no...
If the display works fine when connected to external screen via VGA connector then then the problem is either with the LCD display panel ( which consists of the display panel and inverter ) or the LCD cable that connects the LCD to the motherboard. You could try to re-seat the cable connection on the back of the LCD panel.
1helpful
42 inch lcd fell off tv stand put big dent in screen everything els works ok can new screen be fited and wot cost
Almost all of the time it is not economic to replace the LCD panel.
There is a market for broken LCD TV where the circuit boards are used to repair
units where the glass display is intact.
Advise selling your broken TV on Gumtree / adtrader or equivalent and buy a new unit.
6helpful
3answers
MY PROBLEM IS THAT THE SCREEN IS CRACK AND NEED TO BE REPLACE
LCD Screen replacement would cost you approx 70~80% of new tv price. New tv is better option.
My son just hit his rattle into the screen of my flat panel tv. when turned off it looks fine but when its on you can barely see the picture in the top right hand corner but the spot that he hit it it...
Ur tv have a broken LCD screen panel.Not worth fixing,because the LCD screen panels are limited produced,will cost the same as a new tv,if replaced.Only can buy the LCD screen panels from the tv corporations.Sorry,worth as a whole tv any more.Now ur tv,only worth as salvage for eclectronic boards.
1helpful
2answers
We have a 37" LG 37LC7D flat panel TV and we have broken the screen. (Wii game) Everything else on the TV is good. Is there any way to repair or replace the screen? Would appreciate your help. ...
It is so sad that you got your screen broken.
Yes you can have a replacement screen but you might need to locate the manufacturer service center around you at your location. I have had a replacement before too. It will not cost so much.
Good luck and rate this.
LOST THIRD OF LCD SCREEN,ALL FUZZY ON A DCP850
Ur LCD screen panel is broken,it junk can't repair LCD screen dead not worth it to repair.
Broken LCD Screen on a Vizio VW42L. Where can I buy one?
Hello Sesman200,
We have a good screen in Stockton, CA... Call us at 209-465-6139 .. Dave
Thanks.
2helpful
2answers
Dynex dx-lcd32-09 lcd screen broke
If the LCD screen is broken, you should consider selling your set for parts. The cost of a LCD replacement is not cost effective. Examine the screen to verify.
If the LCD screen is good you can check to see if the "image" is being "sent" to the screen.
1) Take a bright flashlight and place it against the screen with the set on.
2) If you see an image around the edge of the flashlight the problem is in the inverter/CCFT or the power to it.
3) If you do not see an image the problem is probably in the LCD Controller (TCON) or its connections.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
