Question about Toshiba DKT2010SD Phone
How do I change outgoing message on our phone so that I can add a new employee's mailbox? We have a toshiba dkt2010-s
Posted by lmk1243 on
J.R. Trowbridge
    New Friend:
  • 66 Answers
It depends on your phone system and Voice mail. If you have the Stratagy voice mail it can be done through the phone. we have guides avail. idacomusa.com
Posted on Feb 11, 2010
I have a Toshiba 3010DKT- SD. How do I change the greeting people get after hours when the phone is in "night"? Actually, how do I set up "night" mode?
Night greeting usually resides (and managed) in Mailbox 990 (Message #2). You'll need the passcode for that mailbox or your dealer will need to reset it.
Sep 19, 2014 | Toshiba DKT3010SD Corded Phone
Employee forgot his password and need to change the voicemail for new employee. Is there a way to reset the phone. Phone model is a Superset 4025. My phone number to the phone is (563) 690-3230 or email...
Each mailbox password is held in the system programming of the voicemail system. You need the system admin password for voicemail. Dial the access code for voicemail, if from a phone with voicemail then press * to get to the main greeting. At the main greeting dial * then the system admin mailbox number which is 99 for 2 digit ext numbers or 999 for 3 digit ext numbers or 9999 for 4 digit ext numbers then you will be prompted for the system admin passcode(default 1234). Press 2 for add/edit/delete (Never press 1 for new installation or you could delete all current voicemail programming and messages). Press 2 to edit mailbox, you will be prompted for the mailbox to edit, enter the mailbox number. Press # to skip to the passcode reset, enter the new passcode or press * to reset to default(999) then press # for each of the remaining parameters until you are returned to the mailbox menu which prompts for press 1 to add mailbox, 2 to edit mailbox, and 3 to delete mailbox, then hangup.
Dec 07, 2010 | Mitel Superset 4025 Corded Phone...
Need to change password on voicemail extension on
If it's a Panasonic brand voice mail, you administer the system from the System Owner's mailbox (999). With that, you can use option 4 or 5 and reset the mailbox password to any and all mailboxes (except 999 :-)
Carl
Sep 03, 2010 | Panasonic KX-T7420 Corded Phone
An employee changed the password to the voicemail, and they are no longer with us. How do I override their password and change it back to the default password for the new employee?
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234. If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. ,(depending on version) press either 2 or 4 administer extensions, enter the mailbox number of the box you want to reset, press 3 to re initalize the password, hang up when done
Apr 09, 2010 | Avaya Lucent Partner 616 Phone
How do you change the phone message?
You can get your entire manual here:
http://www.p1bc.com/toshiba/toshiba_dkt_2/DKT2010-H.htm
May 13, 2009 | Toshiba DKT-2010H Corded Phone
I have a Partner-18 and need to reset the password for a user
Delete the mailbox for this extension then re-create entire mailbox.
May 04, 2009 | Avaya Lucent Partner 616 Phone
How do I change the voice mail recorded message? How do I get a manual for this existing system?
IF you know the password for the mailbox then log into the voicemail by dialing the Stratagy access code, after Stratagy answers dial * , then your user ID mailbox number plus #, then your security code plus #. The User Main Menu plays, press 2 to change your greeting, the Select Greeting Menu plays, press the greeting number, the Record Menu plays, press 2 to record your greeting, Record greeting, as soon as you finish press #, the Record Greeting Menu plays, press 1 to review or 2 to re-record. Press 9 to save and return to the Select Greeting Menu and 9 again to return to the User Main Menu, hang up at this point.
Jun 08, 2008 | Toshiba DKT-2010 Corded Phone
Changing Voice Mail Password from the TOSHIBA DKT2010-SD set
you will need to download the manuall you should be able to get it off this sight hope this is some help
Oct 30, 2007 | Toshiba DKT-2010 Corded Phone
Toshiba DKT2010SD Phone Logo
235 people viewed this question
Top Toshiba Lands Phones Experts
Marvin
Marvin
Zaid Anarwala
Zaid Anarwala
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
