Question about Brother MFC-8640D Printer
I have an error message, Brother MFC-8640D Printer
I have an error message, "Check Paper MP" what does this mean?
Posted by keith_earl on
Aparajita Batabyal
    Brigadier General:
  • 3,513 Answers
NO PAPER MP
Load paper into the Multipurpose (MP) Tray There is no paper on the Multi-purpose tray. Load paper onto the Multi-purpose tray.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/002100/000073/faq002173_005.html?reg=eu&c=eu_ot&lang=en&prod=hl3260n_all
Thanks
Posted on Jan 15, 2010
I have a brother MFC-9440cn printer. The printer is telling me to load paper in the MP load. I need to use the tray instead of the MP load. How do I go about doing this?
When you ready to print your computer.please go to print properties setting paper source default or tray 1 or MP.MP mean multi pass tray.I mean front paper loading tray.
Jan 14, 2010 | Brother MFC-9440CN Laser Printer
I have a Brother mFC 8640D - paper feeds through
The black exit rollers on top get slick from the paper and toner, they need to be cleaned with a damp rag. You hold the rag against them 1 at a time and open and close the front door so they will rotate while you hold the rag on them. Should help the paper exit.
Oct 02, 2009 | Brother MFC-8640D All-In-One Laser Printer
I have a Brother 8640D all in one printer. There is a grinding noise when I go to print. The paper is going through the drum and they getting stuck before coming up and resting on the try where I pick up...
if its going through the drum, then its stopping at the fuser area.
you have a broken gear on the fuser. the fuser will need to be repaired. approx. cost for fuser repair will be about $75.00
Jun 25, 2009 | Brother MFC-8640D Printer
Clicking noise with MFC-8640D
Make sure that the paper guides in your paper tray are not holding the paper too tight against the front of the tray, there should be about 1/16 inch play so that the paper can be lifted to the roller easily. Also take out your toner and drum and turn it on, if the grinding noise is gone you may need a new toner, some refilled toners are too tight to turn properly.
Jun 24, 2009 | Brother MFC-8460N All-In-One Printer
I have brother MFC-8640D printer How can i get the software
From the manufacturer website! :-)
http://www.brother.com/html/download/index.htm
go to the search box and put your model no. in....
Jan 28, 2009 | Brother MFC-8640D Printer
Need paperport software for MFC-8640D i tried to download software drivers from Brother site as i lost CD but unable to get drivers or software for scanner ie paper port software can you please help me to...
Hello Jim Try getting your software from www.cnet.com I pointed another FixYa user in the same direction this Morning and they pressed the Blue FixYa button after download PaperPort for their Brother Machine and well pleased.
I hope this helps you too!
Good Luck,
Paul 'W'
Jun 03, 2008 | Brother MFC-8640D Printer
Phantom paper jam
Same problem here. I'm googling around looking for ideas.
Sep 07, 2007 | Brother MFC-8640D Printer
Brother MFC-8640D Printer Logo
1,361 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
