Whirlpool MH6150XMS Microwave Oven Logo
Posted on Jan 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
THeood is not getting heated and the turntable is
THe food is not getting heated and the turntable is not turning
Anonymous
Level 2:
Scholar:
  • Expert 130 Answers
  • Posted on Jan 15, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
130
Questions
0
Helped
352404
Points
292
The unit inside the microwave that heats called the "magnetron" has gone bad or the circuits that power the magnetron and turntable have failed. if its under warranty still, send it back to the manufacturer. if not you can call some repair shops and see how much it would be to service it, but its most likely going to be cheaper to purchace a new microwave since they are relatively cheap these days, and electronics repair people are not cheap. hope this helps
Frigidaire FFMV164LS 1.6 Cu. Ft. Over-The-Range Microwave. Hello, Can you turn off the turntable on Frigidaire FFMV164LSA? The manual doesn't specify.
Question edited for clarity.
No you can't. The turntable needs to rotate the food or the microwave energy will burn holes in your food. The rotation spreads the heat evenly throughout the food. You can test it by removing the turntable and put a plate on the base with a pound of butter on it. Microwave on full power for a minute. Notice the holes?
1helpful
Bosch microwave oven,turntable not working,food not heated
Even if the turntable isn't turning, the oven should still heat the food but it will be uneven cooking. I would suggest that the unit is not "microwaving" This is usually the high voltage capacitor, fuse or diode failure. You will need knowledge of how microwave ovens work and specialist tools to test these. If you don't, I would suggest you get a tech who does. There are extremely high voltages in microwave ovens.
I have a High Pointe model EM925Bss-s and although the turntable does not work the oven still works. Is this dangerous?
no as long as you never put any metal or foil inside but food won't heat evenly , the turntable can usually be fixed by cleaning out center bearing with Q tip and a shot of oven cleaner this sometimes gets lots of food and grease build up from heavy use machines (usually mass food prep areas) and slows and stops the drive of turntable
Sometimes the turntable would run and then it would quit for days or weeks food still cooked. Now it has not turned in months.
The turntable motor will need to be replaced, the advantage when it is working, the food is heated more evenly when it is turning, but it is not essential to replace.
2answers
Microwave will not heat food. punch in heating time, press start and nothing happens
HI. your control board has failed. you will need to replace the control board asap if possible.
Does not "heat" food.
The Microwave Magnetron or power circuit break down . You need to replacement the parts .
Good luck
19helpful
2answers
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
5helpful
2answers
Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
Top Whirlpool Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
