Brother FAX-575 Plain Paper Thermal Logo
Question about Brother FAX-575 Plain Paper Thermal
Every time I try to fax I get a busy signal. I tried to fax several places and I get the same thing cannot be completed as dial.
Posted by mcclelland39 on
Seth Crosby
    Problem Solver:
  • 13 Answers
I called Canon about this. They had me tweak the transmission start speed (Menu>FAX setting>TX settings>TX start speed). It was too fast. Set it to 4800. Then it was too slow. Clicked it up to 7200 and now it works!! TX Start Speed should not be too fast or too slow.
Posted on Mar 13, 2013
Anonymous
    President:
  • 3,085 Answers
Dial those numbers from a regular phone and listen for fax tones. If you hear a busy signal, then they are busy.
Posted on Jan 15, 2010
Can fax to a toll free number but not to a local number
The easiest way to experiment with this problem is to plug in a phone in place of the fax.Take the list of numbers and try dialing them with the phone.Many local carriers now require for you do dial a "1" before the exchange,even if you are in the same area code.(I live in the D.C. area,and we have to dial "1" first).I believe adding a 1 to your local fax numbers will correct this issue.If not,try dialing another number at your location.If you can call one of your other numbers OK,but cannot dial to a local number even when dialing 1-area code-exchange-last four digits,this may be an issue with your long distance carrier.(Anytime you dial one before the other ten digits,it goes through along distance carrier,even on local calls).
2answers
My Brother MFC7340 Fax Machine will not send faxes it has a busy signal always and a busy signal when someone tries to fax me.
You need to reset the memory, since previously you have dialed some number, which is not able to connect. So restart the printer. Unplug the printer for 10 minutes and plug back the power to the printer.
Hope this helps.
Shane
1helpful
2answers
When I dial a fax number I get a busy signal even though I know that the number is not busy because I have dialed it on my outside line and it works. This has happened repeatedly. I have unplugged...
Since you mentioned that you have an outside line, do you have to use a code to dial out normally? Try plugging in a phone to the line for your fax machine, and attempt to dial the number for the other fax machine using the phone. You should reach the fax and hear a high pitched sequence of tones. This is the other fax machine trying to establish a connection. If you still get a busy signal, try calling the owner and letting them know that their fax machine is not accepting incoming calls.
1helpful
When trying to fax, iam getting a fast busy signal, this problem just strated
This could be related to the fax machine, but more than likely it's a phone line issue. Try sending a fax manually by using the fax machine's speaker or "on-hook", then manually dial the number. Listen carefully as the machine dials and make sure it's even dialing out. Do not hit start until you hear the other fax machine pick up. If the "fast" busy signal occurs before dialing is complete or right after, have your phone line checked.
Trouble faxing
Check the fax line with a regular phone and dial a fax number to listen for fax tones.
Brother mfc-420-cn all faxes are always busy
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
2answers
Have dial tone, but can't fax
It sounds like the modem is bad a possible electric serge
Fax
I'm not sure where your machine is attached. But are you plugged into a pabx or switchboard system? If you are then I think you may either need an access code for either outside like or long distance calls. The other thing is the setting on the machine. Can I assume it is on tone dialing? If it is set on pulse, then it won't work. I'm assuming you are in the U.S. that uses almost all tone dialing. Hope this helps.
Norman  J Weimar Jr
Norman J Weimar Jr
Gary
Gary
