Question about Medical
My sterilizing autoclave, SES 2000 Little Sister has flashed with error ELECT on the screen, it apparently has something to do with a power cut we may of had today, but how do you fix it?
Posted by c_dunn_won on
kuuren
    New Friend:
Press any program button, hold it down, then turn on the power switch. Release it after 2 secs.
Posted on Aug 26, 2010
  • Steam Swami Nov 10, 2010
    Yup, this just means the power went off :Elect - rical failure,,,,,,,
    Any 1 button
  • pipinos Oct 02, 2011
    thank you; I have solve the problem!
krishkonica
Me too please can u guide me guys?
Posted on Jan 23, 2013
Anonymous
    New Friend:
Hi mate
we have the same problem.if you could get your answer or you have solve that, please let me know how we can fix this? many tanx
Posted on Jul 09, 2010
Check the fuses located on both sides of the mains connection in the back of the autoclave. One of them has blown. If both check ok, then check the connection tho the mains. You may have a faulty ground. If you are not comfortable doing this, contact Eschmann at tel:+44 (0)1903 753322
Fax: +44 (0)1903 875789
[email protected]
Mar 06, 2018 | Science & Laboratory
How do I reset error message elect
Providing a make and model would probably help you get more answers.
If you are referring to a SES2000 or LS3, ELECt means power has been removed during a cycle and to clear the error, turn the power off, hold one of the 4 buttons on the front as you power the autoclave back on.
You will have to re-process the load as it has not performed a full cycle.
Feb 12, 2015 | Science & Laboratory
At aproc 103 degrees I get ERR1. Any ideas what is wrong
Here is a link to the technical manual:
http://www.njcautoclaves.com/pdf/LS3-None-Vac-Parts-Explosion.pdf
It doesn't list an error code of 1 just 2-9 so I have no ideal.
Nov 29, 2014 | Cars & Trucks
WHY IS MY EZ 10 GIVING A LOW HEAT CODE
Message is displayed and sterilization does not start if the autoclave has not reached sterilization temp. after heating for 50 mins. while in wrapped or unwrapped programs (80 mins in the Glassware program).
1) Clogged air jet, clean air jet.
2) no pwer to the heating elements.
3) Low line voltage delaying heat up. Not enough power to supply unit.
May 06, 2014 | Tuttnauer EZ10 Automatic...
Error 3
Error 3 is a Door lock error and has nothing to do with the water sensor. Tighten the door down snuggly, but don't over-tighten. If it still doesn't work it may need a door rebuild or switch replacement. Call for service if it doesn't restart.
Apr 16, 2014 | ESCHMANN Little Sister Autoclave Tabletop
Err 01 little sister ses
This is a power failure alarm, meaning the prior cycle failed due to a power failure/ outage.
Verify your power supply is correct for this unit's needs.
Check the fuses.
Beyond that, it may be a wiring/power supply issue. Call for service.
Jan 29, 2014 | ESCHMANN Little Sister Autoclave Tabletop
Short beeping with no error code
...no informative error? bacteriological filter? time for maintenance?
Jan 09, 2014 | Joyfay 12L Vacuum Steam Autoclave Medical...
What are autoclaves used for?
Autoclaves are used to sterilize equipment like those used in surgery or in a microbiology lab. They are also sometimes seen in tattoo parlors for sterilizing the needles.
Oct 20, 2013 | Science & Laboratory
Manual for little sister ses 2000 autoclave
do you recommend that the 1st cycle of the day be empty or is it ok with instruments in place?
Sep 06, 2010 | Health & Beauty
Medical Logo
5,438 people viewed this question
Top Medical Experts
Andrew Taylor
Andrew Taylor
Rhonda Webster
Rhonda Webster
Are you a Medical Expert? Answer questions, earn points and help others
