Question about Hand Tools
Stanley 10-788 how to change blade
Stanley 10-788 (contractor grade retractable utility knife) how do you change the blade? There's a little yellow button, but I am pushing it but I don't know if the knife is supposed to open or how its supposed to open?
Posted by geckopro83 on
  • Ed Reitz May 02, 2012
    The download from stanley toos is not for the 10-788. The yellow button allows you to remove the old blade, but the new blade won't go all the way in.
Jackie Parcus
Push the top metal button all the way foward as if pushing the blade out to it's (farthest) 3rd setting. Then push foward and down one more time which locks the mechanism down. Push and hold the yellow side button as you insert the blade. When the blade locks in all you have to do is release the yellow button and return the top slide to it is fully retracted home. The blade is loaded
Posted on Feb 04, 2012
  • Brenda Kuciemba Sep 30, 2013
    Thank you so much. Excellent instructions.
Anonymous
    Problem Solver:
  • 7 Answers
  • joemkush Oct 14, 2010
    Thanks! I was having the same problem.
Thomas Patten
    New Friend:
Make sure you push the slider all the way forward or it won't release the blade when taking it out. If the slider is all the way forward, and not just to it's farthest setting where it locks. This is about 1 millimeter past where it locks. Sometimes, when you try to push it all the way forward, it doesn't go far enough. So you simply, move it back and then forward again making sure to push down all the way on the metal slider button when going forward to get past where it last locks.
Posted on Jan 19, 2013
Pieter Vleeshouwers
  • Hand Tools Master
  • 2,028 Answers
Posted on Oct 22, 2016
I have a stanley fatmax knife but it doesn't have the small yellow button to help insert a new blade. what can I do?
HI!Kindly pull the button on the end of the knife and then after you remove that you can now put the blade of your knife.
How to open stanley fatmax knife 10-778 TO CHANGE THE BLADE. thank you
How do I change the blade on the quick change/instant change knife? Warning: Blades are sharp and can cause serious injury. Be extremely careful when handling blades. Wear eye protection and dispose of used blades properly, such as wrapping in duct tape.
FULLY EXTEND THE BLADE.
Press down and forward again on the slide button until the button is in the full front of the top slot (0 through 3 in the below picture).
Note- the blade must be extended beyond the 3rd detent position. This will cause the slide button to remain in a down position, allowing the blade release button to operate.
PRESS AND HOLD THE BLADE RELEASE BUTTON ON THE FRONT SIDE OF THE KNIFE. (Step 4 in the below picture)
Note- if the blade is not fully extended beyond position 3) , the blade release button will not work.
Remove the old blade carefully.
Insert new blade.
NOW, RELEASE THE BLADE RELEASE BUTTON.
ENSURE THE BLADE IS LOCKED IN PLACE. If the blade does not retract, try carefully giving a slight tug on the blade to reseat.
1helpful
Have a Stanley Fat MAx utility knife and unable to open it to load the blade
there is a little black button on the end where the blade comes out. With the blade in the out position,push in the button and pull out the blade. With button pushed insert new blade or turn the old one around to use the other end.let go of the button and you are ready to go.
Stanley retractable utility knife 10-788 how to replace a blade [email protected]
Hello. The blade-slide button must be pushed down at full extension, and then pushed forward some more untill the blade can be switched out.
Hope this helps.
Feb 16, 2011 • Hand Tools
2helpful
How do I change the blade on a Stanley utility knife, 10-788?
Hi, W/D here.
The blade changing is accomplished by pushing the yellow button and pulling the old blade out. It is reversible. If there is no blade at the ready, there may be more in the body of the knife, which are located behind a swing out panel on the handle. You'll need to push in the yellow button when installing the blade, and once the blade is in, release the button, and moge the blade until it clicks in place.
--W/D--
11helpful
Describe how you put a blade in FatMax model 10-778
The model in your picture is a fixed blade utility knife (model 10-816). Your question asks for instructions for model 10-778, which is a retractable knife. I'll guide you through the 10-778 which you asked for, if you need instructions for the pictured 10-816 please re-post the question.
Push the thumb slide forward as far as it goes exposing the blade. Press the blade change button on the side of the knife (the small button on the left side near the blade) and pull out the old blade.
Insert the new blade and slide thumb slide back to fully engage blade in the internal lock.
3helpful
3answers
Stanley 10-801 utility knife. How do you change the replaceble blade?
On the pivot end of the bladed knife is a black plug that says pull. They actually mean "Push". push it away from the knife body and rotate the handle half it's mounted in, down. The body will rotate in half , revealing the utility blade and more blades in the rear storage.Also note the blade depth adjustment has a locking detent. You have to push it to the right to unlock the utility blade.and push it to the right when retracting to fully retract and lock the utility blade.
3helpful
I can't open or refill the fat max. Lost the instructions.
If it is a 10-816 then Knife swivels open for easy blade change and clean out - no tools required, much like 10-999
If it is a 10-778, you don't really open it. You press little button on left side, behind the blade wiper, and this releases blade. Push red button on rear of knife, to open blade storage
if it is a 10-999 then press the button on rear and rotate the two halves.
I unscrewed Stanley 10-379 Interlock retractable knife and now I don't know how to put back the gizmo that fell out or the three blades that came with it.
Google: how to change blade in Stanley 10-379 utility knife. Stanley website shows how knife & blade look on the outside. Put it together so it looks like that. Sorry, but ain't don't know how to send the picture to you.
Oct 21, 2010 • Garden
I cannot open the front of the utility knife to replace the blade on model 10-788. Can you help me.. I can open the storage area but not the blade area to replace the blade.
I was able to find the answer on another site. It is really simple when someone tells it to you. You push the blade all the way out then you can push the yellow button and it comes out.
Hand Tools Logo
Top Hand Tools Experts
Bill Boyd
tau1618
Tom Chichester
Are you a Hand Tool Expert? Answer questions, earn points and help others
