My camera shows to be fully charged but when I try to turn it on; it comes on for a second or two and then turns itself off. What could the problem be?
If you have a second battery, try it. If it works with the second battery then the first battery is bad.
If you don't have a second battery, take your camera and battery to a good photo store. They should have a second battery to try. You might be able to test your battery with one of theirs. This will tell you whether the battery or the camera is bad.
Have you fully charged the battery? if it is a new camera or battery,it needs at least 12 hrs of charge,to maintain good charge, if only a short time of charge was given from new the life of the battery will be greatly re-juiced,try a new battery with a full charge, if this fails your camera is probably faulty, take it back to get a replacement.
Did you do the Setup when you first started it? by holding the red button and following prompts? (to set up Language, date etc.) - if not try that. if yes, have you tried recharging it? Mine takes about 7 or 8 hours to fully charge (the red light will come on then when fully charged that light goes out) - it appears you have Ultra HD like me, so you should also be able to try some regular AA batteries in place of your rechargeable just to try that. If it works then, it is your rechargeable battery pack - either no good or needs charge. also when plugged into USB that red light should come on on front of the camera and if you look at the screen it should show a battery icon with a lightning bolt over it, shows the battery -how much charged. after 6 or so hours, press your red button and look at the screen - it now should be showing a battery icon that should by now be mostly Green and almost fully charged. While charging the unit, Flipshare software comes up on your computer, "X" out of that software, so your camera will charge faster. My camera was doing similar things but I've had it a long time, and regular batteries worked, So I ordered a new battery pack and it has been fine since. Good Luck!!!
here is link to "what to do if battery not charging"
SOunds like your battery is bad. try discharing it :
Place the battery in your camera until it itself turns off. In this situation, the battery is fully discharged.
Take out your battery and slide it into your battery charger.
Connect your charger with power to fully charge the battery. It is normal for a new battery that battery indicator shows 100% capacity in 10 to 15 minutes. Please keep charging until there is no time left for charging.
Fully charged and fully discharged or "cycled" as much as five times to condition them into performing at full capacity.
Try it and see if it works? If the batteries are not rechargeable then the problem is in the cameras power supply and you need to take it in or replace it.
Please check whether you're using a fully charged battery. After fully charging the battery if the issue still persists, please try Power Resetting the Camera. To Power Reset the Camera. First, please turn OFF the Camera. Then, remove the battery pack from the Camera. Then, press and hold the POWER button on the Camera for 30 seconds. Then, reinsert the battery pack and check whether the issue is resolved.
Same problem as described above. Fresh batteries, turn it on, see the Kodak screen for a second, then it just turns off. I found that if you swith it to the favorites icon (the only one below the Off position) it stays on and I can review photos. But no taking new photos! Help!!!
This problem is inside the camera. Either power supply or main board. Something, most likely a leaky capacitor or faulty IC, is causing the battery sensor to see too low a voltage and shut down. It could also be the sensor itself.
Possible failed battery showing fully charged but actually not -or even charger.No reset]
Disconnect from the wall socket- re connect and tell us if the battery is now charging.
If show full- replace battery.
Also tell Sony customer support
