Question about Nokia N-Gage Console
My n-gage accidentaly felt in water. when i got it off from it the screen was turning black and white. after that it stopped working,cant open it anymore. can it still be fixed?
Posted by dj_kmiktz3 on
nomadtech
    Problem Solver:
  • 5 Answers
No, you should have waited until it was completely dried before turning it on. I'm afraid it is fried now.
Posted on Jan 14, 2010
I have a 2004 f150 ford explorer. I have been having troubles with the gages dropping so I took it to my mechanic and they found various codes in the odometer reading area. they searched the codes and they...
Check the ground points. You don't need a cluster. The cluster will not turn the radio or anything else off. I don't have the ground points for the f150. You can probably find them online. Since you're having problems on the inside, look under the dash. Common points are at each side of the cabin area by the side kick panels. Also around the steering column. Any black or black/white wire will be a ground. Since the truck keeps running, the grounds under the hood are probably fine.
Oct 16, 2014 | Cars & Trucks
I accidentaly stepped on my tablet and the sscreen seems to be cracked. Where can i buy a screen replacement, and how do I replace the screen without damaging tablet more?
Ebay has the screen but you need to be sure of what model you have,it is difficult if you are not into electronics to replace it and you need to buy the tools,google how to fix it on the internet,So if worried that you cant fix it take it to an Apple store.
Dec 28, 2013 | Mach Speed Trio 4.3" Tablet with 4GB...
Everything is working well except gaining access to the second screen. Pressing the advance key takes the first screen away then brings it back to the front, wihtout stopping at the second screen. The...
I still had both pieces of felt on mine and it failed like that. I took Ross' advice and just put a piece of electrical tape over both pieces of felt, a bit more than twice as big as what he suggested, and it worked fine. Easy access for me was to remove one of the back panels (4 screws) and then turn the unit on and then off when I saw the felt (in your case it may be where the felt used to be).
Thanks Ross. I found this thread by clicking on windledom in a different thread.
Sep 01, 2011 | Panasonic Panaboard KX-B530 Graphic Tablet
Hello, I hava a problem with our KX-B530. The indication for the cause "screen does not move" is blinking in the error indicator field. When i'm pressing the copy buttons nothing happens but...
Hi, on the bottom of your screen- just hidden inside the lower plastic trim, should be a black felt tag that lets the sensor know where the page should stop. Sometimes these curl up and fall off. You should see that at least one tag is on one of the screens. Mark on the plastic frame where that black felt stops with your finger or a bit of sticky tape. Turn off your machine and move the screen by hand. You can tell where it should stop for the next page as usually the screen has some minor rounded folds where it sits on the rollers.
When in position- use a permanent black pen to draw a small 1cm high by 3cm wide black box as low as possible on the screen where the old tag fell off. It may still be there rolled up- you could then reglue it if it is there.
Sometimes no felt is visible, but the previous glue/sticky gives you a clue- usually about 5cm to the left of centre you will find it. If your put the permanent pen in the wrog place, metho will remove it. If you are worried- try a w/b pen first. Perhaps only a small part of ther felt is missing.- Ross
Feb 08, 2011 | Panasonic Panaboard KX-B530 Graphic Tablet
I can see the moon clearly through the viewfinder but when I look through the eye piece holder I cant see anything. only a dim white blur. I assume that the black felt on the front lense needs to stay...
I don't understand about looking through the eyepiece holder. Is there an eyepiece in the holder? Without it you won't see anything. With it, you will see fuzzy blobs if it isn't in focus. Try using the least powerful eyepiece that you have to start with. Finding focus with the more powerful ones takes practice.
I also don't understand what the black felt you refer to is. Telescopes normally have a protective cap over the front opening, which is removed for viewing, but I have never seen one made of felt.
Nov 21, 2010 | Meade DS114-EC Telescope
Iphone screen white, clicks and turns on and off but cant see!
if is not water damage , apple should repair it. If not well open the iphone go to youtube see vid how to open it. turn off iphone open it just pull off #1 and put back in. that's the lcd connector. This should work if not take #1 then #2 and # 3 put all conector back that should work. #1 Lcd conectot #2 is the Digitizer #IS the ligth. If you got gray lines the lcd may be broken.
Apr 04, 2009 | Apple iPhone 3G
Frozen white screen & background
i do to and i cant get another fone as i cant afford to get a new one . mine occured wen i was reciving a video from bluetooth it froze then i took out the batttery then put it back in but wen i turned it on i had a white screen and also now wen i turn it on it dosnt turn on at all then only thing it eva showns wen it is on is a white screen. - bloody hell i wrote an essay
Dec 11, 2008 | Nokia 2630 Cell Phone (Unlocked) - Black
Screen
Can you see water inside the LCD? if you can have a professional clean it out for you. If not, try replacing your battery because if it somehow got wet too then water does more damage to the battery than the rest of the phone. if it's still not working reply here and I'll help further
May 22, 2007 | Motorola Mobility RAZR V3
White LCD on my canon
Hi: I think you have broken (accidentaly with the fall) the cable with several wires that connect the LC display. My real advice is that you take your camera to a store were they can give you direct support desmanteling the camera and replacing the cable or fixing it. However, Zair already had a problem like yours and the best solutions was given by BowerR64. You can consult on the following page: http://www.fixya.com/problems-solutions/t103443,p294056/Canon-PowerShot-G2-Digital-Camera.aspx (just copy and paste on the address bar) ;) Regards
May 21, 2006 | Canon PowerShot G2 (Black) Digital Camera
Nokia N-Gage Console Logo
48 people viewed this question
Top Nokia Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
matt
matt
Les Morrison
Les Morrison
Are you a Nokia Video Game Console and Game Expert? Answer questions, earn points and help others
