Question about Electronics - Others
The reasons for the generator dose not generate electricity are as follows:
1, the magnetic pole of the generator loses magnetism;
2, the excitation circuit component is damaged or the circuit is broken, short circuit or grounding phenomenon;
3, the exciter brush has bad contact with commutator or the brush frame pressure is insufficient;
4, wrong connection of excitation winding, opposite polarity;
5, poor contact between generator brush and sliding ring, or insufficient brush pressure;
6, broken circuit of generator stator winding or rotor winding;
7, loosening of generator lead wire or poor contact between switch and wire; Fuses, etc.
Posted on Sep 28, 2018
SOURCE: Portable Generator doesnt generate any AC Current
is there a manual reset circuit breaker somewhere?
Posted on Dec 22, 2008
SOURCE: coleman 5000 generater-no AC output
Pull off the cover at the end of the generator and locate a 2 lead capacitor, it should read 130UF 200V and replace it, they often go bad and you will not have any output if they are. colman has them for 20.00 shipped. 1-800-445-1805
Posted on Feb 04, 2009
Try replacing the capacitor. You can buy it from http://www.jackssmallengines.com/do_it_home.html. When you pull off the power end of the generator look at the diodes also. If they look toasted replace them as well
Posted on Feb 07, 2009
SOURCE: onan microlite 4000 generator no output
Hi, The 4000 rv unit unit is equipped with full diagnostics, and is indicated by the status light blinking. The blinking sequence, blinks a code as to the fault. If your unit runs and the status light is on without blinking, it is either the circuit breaker on the genset or in your distribution panel that needs to be reset. Good Luck, this should Fixya!
Posted on Mar 02, 2009
SOURCE: My coleman 1500 generator runs fine but does not
Should be a circuit breaker on the side where the outlets are. Could also have a reset button that pops out. Good luck
Posted on Apr 26, 2009
Oct 25, 2017 | Generac Electrical Supplies
Dec 16, 2016 | Electrical Supplies
May 30, 2016 | Briggs Electrical Supplies
Jul 10, 2011 | McCulloch 13HP 338 Cc Portable Generator #...
Apr 16, 2010 | Coleman Powermate Premium Plus 6250W...
Apr 20, 2009 | Electrical Supplies
Jan 10, 2009 | Coleman Powermate Powermate 5000W...
Jan 09, 2009 | Coleman Powermate Powermate 5000W...
Sep 24, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
399 people viewed this question
