Question about Dirt Devil SwivelGlide Bagged Upright Vacuum
How to replace wheel bracket on dirt devil. I have a dirt devil swivel glide and I took off the wheel bracket to clean out a clog and now I cant seem to get the wheel bracket back on.
Posted by jlew8 on
3 Related Answers
galati2k
PETE GALATI
  • 281 Answers
SOURCE: Dirt Devil Swivel Glide
look on the underside where the brush roller is and unplug it first then try to turn the brush roller by hand,if it turns real freely the belt is broke.you might have a clog at your intake hose at the bottom its the clear looking hose that goes from the bottom and comes up the back.if the belt is broke before you put a new one on clean the motor shaft there might be some old belt rubber on it ,otherwise the new belt won't last
Posted on Apr 09, 2009
Anonymous
  • 10 Answers
SOURCE: Dirt Devil Swivel Glide Platinum vacuum suction problem
Is the suction tubing in the head assembly clogged, is the belt broke? If the if the belt looks good the brush may be turned off and you may need to turn the brush switch on.
Posted on May 26, 2009
jlkowerysr
  • 70 Answers
SOURCE: How do I repalce the belt on Dirt Devil Swivel Glide upright vac?
Four screws hold the bottom plate in place. Turn the vac upside down and remove the screws that hold the cover(bottom plate) over the brush roll in place. Remove the plate and you are there.
Posted on Oct 24, 2009
How do I get the bottom of off the dirt devil swivel glide
The bottom does not come off. If. You remove the screws the top cover can be removed to gain access to brush roll, belt and motor compartment
Feb 15, 2015 | Dirt Devil Vacuums
My dirt devil bagged upright(swivel glide) wont turn on..light on
  • its clogged that is what the light shows is that if your vacuum is clogged then that light will come on and it will shut off, i have the same vacuum and mine does not come on cause its not clogged
Mar 09, 2010 | Dirt Devil SwivelGlide Bagged Upright...
Oct 22, 2009 | Dirt Devil M088910 Swivel Glide Vision...
Swivel glide has no suction in the hose but seems to have a bit at the head, definatly not alot. can i fix this myself somehow?
Get ahold of a plumbers snake, disconnect the hose and run it through unclogging it .
Undo hose and see if there is suction right at the socket where the hose plugs into to see if there is suction there.
Inside the place where the bag goes, at the bottom there is a motor dust filter, see if it is clogged.
Also at the beatter brush, make sure that there is not dirt crammed around the nozles input, and check to see if the belt is not slipping on the beatter bar and remove the wound threads from the beatter bar it self.
Best!
Robert!
Oct 02, 2009 | Dirt Devil SwivelGlide Bagged Upright...
May 03, 2009 | Dirt Devil SwivelGlide Bagged Upright...
Jan 03, 2009 | Dirt Devil Featherlight Bagless Upright...
Dirt devil swivel glide - no suction
check the filter gauze on the unsud of vack where bag is if this is blocke you will not have vacuum as there will not be ventilation thro this filter should be able to feel blow of air from this vent when vacuuming up hope this helps good luck from uk !
Nov 02, 2008 | Vacuums
Dirt Devil upright vac
It could be a broken handle release, but it also could be the the clamps where the handle asm, and the base hold together came use, this will cause this problem on some Dirt Devils. The top has to come off to check this out.
Jul 13, 2008 | Kenmore Progressive Bagless Upright with...
Attachment hose has no suction
Sometimes when you take them apart and
reassemble the vac (the plastic slide doesn't
make full contact with the lever,or it isn;t on
the lever at all) that switches
from the floor to the attachment. IF Tthere
are no clogs in the duct then that the
most likely problem
Nov 18, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Dirt Devil SwivelGlide Bagged Upright Vacuum Logo
91 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
