All faxes we send out appear black and copies we make are dark gray. We installed a new drum a months ago. We installed a new toner last week. This problem occured at same time of toner outage. Is there something we need to do to reset it?
SOURCE: Copies and outgoing fax quality
your machine most likely has toner spills in it.
if you send faxes face side down follow these instructions ;
1- take out toner
2- look for thin glass strip on bottom inside the machine
3-wipe clean
if you make copies side up then do the same except look for glass strip on the upper side of machine
SOURCE: Black line on faxes
Check carefully the glass, a very small point of ink or anything else can cause the black stripe. usually it is that the problem. use windex to clean it.
SOURCE: On my Brother MFC 4800 LASER plain paper
yes indeed. i'm sure by your symptoms, thats what it would be.
