2006 Scion xB Logo
Posted on Jan 14, 2010
I have 2006 scion xb and when driving the rpm stays around3500-4000 when running 65 mph can it be modified to run lower rpm
  • Dave  C
    Dave C May 11, 2010
    The only practical way is to put taller tires on it and take into account that your speedometer is reading too low. 185/65/15 or 195/65/15 would give you a little more "legs".
Anonymous
Level 1:
  • Contributor 10 Answers
  • Posted on Jan 15, 2010
Anonymous
Contributor
Level 1:
Answers
10
Questions
0
Helped
12007
Points
33
3500 is about normal for an xb at 65 mph. My previous ride was a pickup and rolled at about 2000-2500 on the highway. But the XB's engine is way more "tightly wound". Your rpm gage should run at about half of of your speed...ie: 70 mph will be about 35 (3500) rpm, 80 mph will be about 40 (4000) rpm. Freaked me out when I first got the thing, but after researching it Ive found out that with a stock engine it actually runs more efficient at the higher RPM's. The 06 boxes won't redline until 6000 rpm, so unless you are driving 120 on a frequent basis you're good. You can probably have it modified to run lower, but you will lose the awesome gas mileage and overall it is not going to improve the way it runs, and would have no benefit............
2004 Scion xB instrument panel & blinkers not working?
That is a mess and points to nothing in particular, perhaps a communication issue with the BCM?
You need an auto electrician with a professional grade $5,000 scan tool computer with access to wiring data and the ability to read wiring diagrams.
https://www.google.com/search?q=auto+electrician+near+me
https://fuse-box.info/scion/scion-xb-2004-2006-fuses-and-relay
I have a 2008 Scion xB and accelerator pedal I can't accelerate very little but that's it it won't accelerate
scan it , it will tell you why.
if TBW fails throttle by wire fails speed is like 20mph max or less. on purpose., so scan it.
also if RPM is low foot ******* the throttle.?
then engine power lacks, scan it.
if RPM goes way high but MPH not same increase,the transmission is dead or slipping.
2answers
Remote starter only allows my starter to turn over twice; needs at least 3 with my key. How to adjust to have it starter run longer on remote?
I know you are looking to have the remote starter run a third time but I would say you need to look at your Fuel Pressure Regulator on the Scion. Sounds like it is not holding fuel pressure at the fuel rail and that is why it requires a third Crank
Why does front end vibrate at crusing speed
I would say you have a problem with the steering part of car, have a mechanic look at it
1helpful
3answers
Vibration when trans shifts to 4th
Fyi....I know this post is several years old but if my answer can help someone it's worth it. I took my car to the dealership today for literally this EXACT problem on my 2010 Scion xB with 125k miles. I read this post and was shocked to read that someone else's xB was behaving the same way under the same conditions. In 4th gear at around 38 MPH and 1500 RPMs I get a vibration and a noise that, like the OP said, sounds like you're going over a rumble strip. That's the perfect wat to describe it. The dealership told me that it needs a torque converter. They want to charge me a thousand for the part and another thousand for labor because they've got to take the whole transmission out of the car and it's going to take 2 days (really 9 hours, they said, but they'd be keeping the car 2 days). I'm currently calling around to see if ANYONE can do it cheaper, but just in case anyone else comes here looking for an answer to this question, I hope this helps. Torque converter might be your problem.
Scion xb rear wheel bearing noise
yes and no most warenties cover the engine and drive train, but with it being this new i still would take it back to the dealer to see if it is covered
1helpful
2answers
The RPM of Nissan Altima stays high when drive over 65 MPH.
No....the rpms differ from engine to engine and from manufacturer to manufacturer. RPM's are always higher at higher speeds.
Check eng , light stays on, goes off, then back on,, lower fuel milage
Hi,If your car have more than 50 k miles ,try oxigen sensor...
Top Scion Experts
ZJ Limited
ZJ Limited
Arnie Burke
Arnie Burke
Are you a Scion Expert? Answer questions, earn points and help others
