Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
The icemaker in the door of my kenmore side by
The icemaker in the door of my kenmore side by side by side is broken in the interior and does this mean I have to purchase a new door? my repairman said I did need to replace the whole door and cannot just fix the icemaker or replace it. Thanks. The only info I have right now is ss 2145146 and 106.56563400
Posted by jjackson8047 on
Anonymous
    New Friend:
  • 61 Answers
If you need a part try www.appliancepartssolutions.com
Posted on Jan 16, 2010
Elite trio, 795.755 Refrigerator light stays on, getting hot. Refrigerator space warming up to 45 degrees. Pressing in both door switches gives no clue. Both feel smooth.
Some of these Kenmore Elite refrigerators built by LG have a design defect that has been the subject of a class action settlement. The interior lights stay on even if the doors are shut, turning the refrigerator interior into a version of the child's Easy Bake oven toy. There are many cases where plastic interior parts of the refrigerator got so hot they melted. I replaced the 60W incandescent bulbs with 7 Watt LED bulbs just in case. The LED bulbs will not get hot enough to harm anything even if left on indefinitely.
This model also has problems with the wires inside the door (water dispenser side) The wires break inside the door and are not replaceable. I ran new wires through the interior and bypassed the broken wires to avoid buying a whole new door.
May 21, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Water is not getting to my icemaker...I swapped the solenoids and pressed water dispenser on door and now i get water to icemaker...not sure what that is telling me is bad
You swapped the solenoid's wires. Switch the wires back.
It means the ice detect lever is up or broken on the ice maker.
See the article on ice makers at How stuff works.com
Apr 17, 2010 | Kenmore 57029 Side by Side Refrigerator
No water to icemaker. Water in door works well.
the water that enters the ice maker is controled by a thing called a solenoid valve (electricaly operated) the" water in door system" is a manual operated valve.. typicaly when the ejector rolls around to put the ice in the tray the solenoid opens lets water in then closes could be solenoid / wireing or controler
good luck
Oct 23, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore - ice maker won't produce but water in door fine
Most of the times the solenoid ( electric valve that lets water from the line when the ice maker calls for it) leaks and this little water freezes up inside the filling tube for the ice maker , in tnis case the solenoid has to be replaced.
Oct 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker in a Kenmore Elite Side by side refrigerator
check the head of the icemaker and see if the gear is broken on the module
Nov 26, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker has ice in it but will not dump in bin!
before i would worry about the lights flashing lets pull the front cover off of the icemaker and verify that the drive gear is not broken.
on the bottom of the icemaker is 1 screw. remove that screw then just slide the entire icemaker out of the refrig so that you can access the front cover. if the gear is broken just replace the front motor module pt# 8201515
if the gear is fine then located in the toe grille of your refrig is a tech sheet that will help you troubleshoot red light blinking.
Dec 17, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No ice
if you remove the icemaker there is a white cover over the head of the icemaker, pull the cover off. youll see a gear in the center. in the middle of that gear there are two plastic tabs that hold it in place one or both of the tabs may be broken cause a bad conection behind the wheel. if tabs are broken you need a icemaker modual (part the gear is attatched to) if not broken you need a watervalve located on the bottom right side behind the freezer
Nov 19, 2007 | Kenmore 53542 / 53544 Side by Side...
Kenmore side-by-side fridge icemaker
yes. replace the icemaker modual and your problem is solved
Nov 19, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
123 people viewed this question
Top Whirlpool Refrigerators Experts
Michael Thomas
Michael Thomas
jdthefixer
Marvin
Marvin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
